The battle of the DACs, comparison of sound quality between some DACs
  • Thread starter Thread starter Deleted member 537459
  • Start date Start date
We did a listening day to compare various dacs....
Thanks for sharing.
The real danger is in spending all that extra money required to make a DIY DAC sound decent... and then realising that for the same money.... you could have bought something that sounds really great out of the box.
However, for a true DIY-er..... learning, experimenting (and money spending) is all that counts and there's simply no other way.
This review seems tendentious to say the least. The DIYINHK board is not very good and the implementation with Bisesik(?) transformers is very "audiophile". Twisted pear lego-approach is also non-optimal. So the only conclusion to draw is that ES9038PRO is not suitable for audiophile mods.
Why not make this more relevant and use a proper ES9038PRO implementation such as Topping D90SE in the comparison.
...as the IV stage is integrated into Andreas discrete...
Not seeing a clear IV stage in the pic below. Looks more like direct out from the resistor array.
The good thing is most of us are not hamstrung by conventional common sense 🙂
Per example it seems very hard to match dollar for dollar the sound quality of a Denafrip's discrete dac using discrete modules available to the diyer. Has that stopped anyone?
Reactions: wlowes
Seems the listening panel's tastes were all geared towards NOS...
I think if you want to get decent sound out of an ESS DAC, you need to as a minimum upsample prior to bypass the average oversampling filters and avoid the internal volume control which to me, sounds grainy and flat.
If you can upsample to 352/384, run in OSF bypass mode, run in True Sync to bypass the DPLL and go PCM interface directly to HyperStream DAC. It gets much better, but it's a lot of work..
Reactions: YashN
The review did not include any measurements but for the DIYINHK ES9038PRO with Bisesik transformers this will probably look very similar. I don't really get the point of using transformers with ES9038 to get such added distortions and other artefacts. But surely properly implemented ES9038PRO with 120dB SINAD will sound dull and bland in comparison 😉
Reactions: analog_sa
Agreed. The D90SE is a known standard that measures super low distortion, is reasonably cost effective and has a decent user base.
It would also be worth throwing a top line MB DAC such as MSB or Holo May. This is the area Andrea is playing in.
Joseph K once wrote to me that the D90 uses individual ADP7112's for each Vref channel, and that "the noise density spectra of the ADP7112 is.. scary..". Looking in the datasheet, it seems to use a voltage reference with a very high impedance, integrated low-pass filter, causing lots of subsonic noise. In a DAC, that causes noise skirts around the signal.
Wouldn't expect a preregulator to help that in most cases. However, IIRC ADP7112's were running near dropout. Don't know what effect that might have. Might have been right around 200mV differential from input to output. Based only on vague memory of being surprised about it, don't think I kept a measurement note.
