Humble Two. 15 Watt Class A. JFET input IRF540/9540 output.
Here I will publish a new amplifier.
It is called Humble Two.
It will output 15 Watt Class A in both 4 and 8 Ohm.
With low distortion.
I publish the simplified diagram now.
I will be back with more details later.
Reactions: joensd and stv
I intend not to build it.
But would be pleased if somebody would do it.
Transformer should be 2x12VAC.
For now you can seee how it looks. See first image.
Fourier Analysis shows THD is very low.
When I added two pole comp it was lower and ended at 0.000064%.
The second image shows the frequency curve in AC Analysis.
I will continue work and see if I can improve it.
I will check in 2SK209, if I have a SPICE Model.
Of course we do not need to have LSK489. Other JFETs can be good too.
I have 2SK209 in SPICE.
The model has IDSS 3.29mA
So I will use 3mA bias.
