Photo Gallery
Minimalistic design for this RIAA Phono pre-amp, schematic by David Kennedy for dignified a vintage “brand new” from 1976 Sony Turntable PS-3750.
The goal was to build the power supply in the same chassis but at the end worked, the pre-amp is incredibly quiet, sound fantastically well, still need the printing and a good knob and some good foot for finish it, for now I am enjoy John Coltrane 😉
Reactions: aroS3 and decramer
Interesting and attractive build on a couple of levels.
Is there any problems with the MOSFETS being heat-sunk to wood?
I'd like to know what part you used for hooking the MOSFETS up to the circuit? The white connectors.
Thanks.
Hmmm...
12GT5/6GT5- interesting big bottle pentode novar. Seems few amps used this horizontal sweep tube, but those few seem quite happy w/ performance...
Big plate dissi- potential big sound capable?? What say you on your listening/ building experience KBX?
Thanks,
Jim
Thanks.
No problem with the mosfets I just move them out of the pcb for practical reason, in case one blows up are easy to replace, the white connectors are JST XH2.54mm 3 wire connector, the heat sink is not needed in this application for feed only 4 6N2P, real wood is also insulated so no problem....all the best
Hmmm...
Thanks,
Jim
It sounds the same as most of the amps I build with this family of tubes (GE5,AV5) TBH. Quite a fast/transparent amp really...
They are working as triodes... 320V@60mA Pd... 2k2:6R or 3k:8R load ratio.
Hmmm...
Thanks,
Jim
i made an all pentode 6bn11.12gt5 set, no global feedback, sounds fabulous....
