Need recommendation for 10 inches full range drivers.
I have a pair of the Lii silver 10's and I consider them very good, in fact they are currently in my primary system. They do require some EQ, what you would call "baffle step", but they have great articulation and are revealing of amplifier character.
:snail:
Dear Mr. Pass,
I am writing you because I am wondering what quality coils people are using for the BSC of the Silver 10 drivers.
I am planning to use a 2,5mH with a 8ohm resistor.
1. What is the value of the coil that you are using?
2. What quality coil will be sufficient?
Please find attached two options for me, do you think the air core is sufficient or can I better go for the wax coil? I think the Silver 10 are very revealing drivers and it might be audible.
Best Regards,
Koos
Dear Mr. Pass,
Best Regards,
Koos
I use an active filter, very simple, having two resistors and a capacitor followed by a jfet buffer, this between amp and preamp.
Any decent coil in parallel with a resistor can do a similar job, but does reduce the damping factor. I suggest playing with the values - mine was set to transition around 2 kHz to -5 dB or so.
I referred to it as a "baffle step" because it's the same sort of filter, just slightly different values.
Reactions: Acoustic Emotion
Thank you Sir 😎
For a passive BSC circuit, just good quality aircoils are good, no need for special esotheric stuff as it does not really matter. And as Lii drivers are low wattage, a 20 AWG thick wire for the coil is more than good enough. So something like this would be good enough:
https://www.soundimports.eu/en/jantzen-audio-000-1940.html
Please take in account that the coil also has a resistance (the dcr) and calculate that in your BSC circuit.
Great, thanks for your clear advise!
