I'm glad you asked. Here is the LDO noise: https://www.diyaudio.com/community/...ee-15v-and-6-5-3-3v-power.297147/post-6944374
Here is the DAC measurement: https://www.diyaudio.com/community/...trumentation-applications.347854/post-7021805
In the second measurement the DAC is fed by similar LDO. I have not measured the LDO output on that DAC as the end result is what matters.
Thanks for your encouragement, I encourage you to answer the questions which are asked not the ones you'd like to be asked.
More likely hurt his audio business.Sorry if I hurt your feelings.
Conclusion:
On my crappy board it'll make no difference at all and I can use whatever LTxxxx I want.
I have no idea what you guys talkin about the last 3 pages 😆
One last question tho:
Did anybody of you guys actually heard or messured this particular board I posted? Because to me it seems to be a way newer version than the other boards from the beginning of this thread.
Maybe it doesn't sound as bad as you think?
Or can you tell from the picture I sent that it's a crappy design?
You can tell from the picture that it shares the same design as the original board in this thread. Only 1 op amp which practically dictates the inferior voltage output mode. Regulators seem to be 7805 and AMS1117 which means that it does not help much to have better regulators feeding the board.
it will definitely make a difference, only that there are probably other significant bottlenecks in the design, at least according to measurementsConclusion:
My recommendation would be to not waste any time on it, unless it was more about learning electronics than building a quality dac, worth your time and money invested.
Okay. Thanks.
Till now I just soldered some cables for wiring Speaker and RCA connectors and stuff.
When I got a working DAC/Streamer Combo with volume control and playing direct DSD I think I will be satisfied.
And maybe I'll have a look around here in the forum to see what's next. :-D
It's more a fun project and of course for the learning effect too. I'm new to this forum and didn't have to do much with the electronic parts on pcb boards.My recommendation would be to not waste any time on it, unless it was more about learning electronics than building a quality dac, worth your time and money invested.
Ideally, you want to look around to see what's first, as in what is the bottleneck in sound reproduction. It's in the speakers and room acoustics.And maybe I'll have a look around here in the forum to see what's next. :-D
Why concern yourself with what others think ? You are the one who is going to listen to it. If it is good enough for you, fine. If not, mod it, if that interests you or try another dac.Maybe it doesn't sound as bad as you think?
What about those who listen to it to their liking and then post claims about it on forums like this one?Why concern yourself with what others think ? You are the one who is going to listen to it. If it is good enough for you, fine.
I can't get my head around your posts on here or why you bother. If nothing is subjective to you why bother with worrying about this forum.... which I seem to gather is about making hi fi sound as good as possibleWhat about those who listen to it to their liking and then post claims about it on forums like this one?
Did someone claim that he makes a living from his audio business?I don't think Richard does this on here to earn a living.
- Digital Line Level
- ES9038Q2M Board
