Output BJTs for buffer
music soothes the savage beast
Joined 2004
Gents, let's discuss the linearity of output transistors, mainly bjt, for power buffer.
Background: I built many amps, and sure can be very happy with quite a few, but recently started experimenting with just buffers. Why? I do not need much power, i have plenty of preamps, and buffers sound much better to me after all.
Maybe its a lack of global negative feedback or something else.
Not interested in starting any flame war about putting shades on mona lisa, creating effect box, or insulting the artist. Fed up with that kind of bs.
I created two fully finished buffers based on c5200/a1943, one based on one output pair, one on three output pairs.
Now i want to experiment with other power bjt for outputs.
I got c3263/a1294.
I got w1302/w3281.
I got w0281/w0302. (I typed it incorrectly)
I hope i typed it correctly. (turns out I did not)
Which of these would be most suitable/linear?
https://www.diyaudio.com/community/threads/direction-of-diodes-in-an-amplifier.379908/page-3
It doesn't matter what final trz you're using as long as its driver can charge and discharge quickly its capacitances and that means that the driver is as important as the final transistor. You'll often see a ferrite bead on the base pin of the final trz in Harman Kardon's rather slow power transistors.Old timers used 1X 200MHz 30 watts drivers for 1X 50...60 Mhz 150...200Watts final trz for the lowest distortions as an example.You can also help a slower output and driver trz placing them inside a rail bootstrap keeping it at constant VCE as in Kenwood l-09M.
You could also try the quadrive concept used in kenwood L-A1 where each final trz has its own driver...all these techniques are used to fight the output trz internal capacitances enhancing the slew rate in normsl 2..3EF stages.
Well, you're definitely not the first to say this. I just thought of Charles Hansen, and also Steve Dunlap (the Krill, on this forum). Charles liked the diamond buffer with the same transistors for drivers and outputs iirc.
Reactions: Bigun
Also, I just remembered a mod that was once proposed. Say you have a feedback amp with emitter follower output with three pairs of transistors. You would take feedback from only the "first" pair, and break the trace right there (disconnect the speaker from this first pair). The other two pairs are running open loop and these drive the speaker.
Reactions: diyiggy
http://www.altmann.haan.de/splif_page/
The base is a little bit weaker but the back emf never reaches the feedback network while the mid highs level is obviously increased by the feedback.The ideea is not really bad avoiding tons of feedback and phase lag theory , ringing....I'd do it a bit differently though, with the transistor's found within the feedback loop driving only the mid highs section of a speaker choosing also a faster lower power transistor for it as its load is not that critical.
Not really a great ideea as the driver runs at 50...100 X lower currents while the thermal compensation won't be as effective with a lower hfe.Of course you could run the drivers at the same currents as the power trz spending a lot of heat on them, but then their ability to work at higher frequencies easier than the 2EF is decreased loosing the native advantage of the diamond buffer.
Yes, I think he ran drivers and outputs at the same bias. People liked it and he made money. https://www.stereophile.com/content/ayre-acoustics-ax-5-integrated-amplifier-ax-5-twenty
I found these later:
MJ15003
MJ15024
MJ15025
But these require adapter. I do not have so many heatsinks as to build buffers with all transistors, hence i am asking which are most linear if used without feedback.
There's not the same scale and amount of detail in the charts, so not easy to compare. But I would say the C5200 looks very linear, look at the spacing between the curves for increments of 10mA of base current. Very evenly spaced = good linearity.
Which one is more linear as an emitter follower is best found experimentally, I think.
