Little dot MK2 coupling caps
Hi All,
I fancy a dig around in my little dot MK2 headphone amp. I'm pretty new to this but think the obvious place to start a bit of modding may be the coupling caps.
According this schematic I found, it seems to be a 220ufd bypassed by a 0.68ufd - both electrolytics.
What type of caps would be suitable as a replacement do you think? Space is at a premium in there so massive Russian cans aren't an option.
Thanks in advance
Hello,
Another thing you could try is replacing the 220uf cap with a bipolar. That should reduce what little distortion there is. Going with a larger value and larger voltage rating should help a little as well. If the change is enough to hear is a real question.
Hello,
Hi, I'm a little confused by the schematic. I thought the coupling caps are the .22uf between the tube stages? The large electrolytics are just before the output to the jack and are bypassed by the .68ufs. Can you help me understand this?
My take on that circuit is that its capable of delivering a substantial shock to the user. The output cap and 10k bleeder have a time constant of over 2 seconds, so the switch-on spike could be nasty - headphone jacks aren't noted for their careful design w.r.t. high voltage.
