Dayton audio dsp boards and maikita
An additional brace to more tightly couple the driver’s reactive energy cancetion would probably have benefits.
Resembles this thot experiment (ignoring the isobarik-ness).
dave
dave
This is a great idea . I need the magnets locked together And the pool vents are small, easy to keep breathingAn additional brace to more tightly couple the driver’s reactive energy cancetion would probably have benefits.
dave
there’s all thread /Jam nuts at the center of the larger resonators in tension or compression and that works really good as soon as you hear any buzzing or anything, a half a turn at most and its gone . But without decent size fender washers that starts to get recessed into the plywood.
Gasket leak at Pmax in both corners of long side path.
.349 (offset driver entry to TL ) weird number..? 20degrees? .349206349 radians? Pi/9 ? 300x.349 is 104.76? 104.76x3 is 3.1428?This is a great idea . I need the magnets locked together And the pool vents are small, easy to keep breathing
(432.2)^4 432 is 12 hours/seconds or sun radius in miles (432376miles) (432)_^ 2 is speed of lighht in mile /sec.(186624) ^2 is .349 is driver entry per martin king?
speed of light as 300. Offset as 30 each from zero. ‘parallel pipe’ as 360 total. Exit at 270/90. Extended to 30 if desired.
We have 16 more of these little 4” monsters. They need to go two enclosures(4x4” ) to compare against the parallel high order box design?
And suggestions or ideas it doesn’t necessarily need to be as loud. In fact a different delivery of bass or type of the sound woukd probably be the best? A RoaR out of pvc and nested sonotube? Or MLTL version ?
Are these input screen shots from an earlier version of HR? The new one looks nothing like yours, so can't replicate it and rhetorically wonder if you exported it, can I install/run it?😄$14.96/each. Instead of $732 the latest price increase of the B&C 18ds115🥲 I need one more of (back ordered) .
not sure , but i have spread this concept around into anything that cancels .13.5,27,54,108,216,432,864,1728,3456,6912,13824,27648…. 55296,110592,22184, 44368, 88736, ….Are these input screen shots from an earlier version of HR? The new one looks nothing like yours, so can't replicate it and rhetorically wonder if you exported it, can I install/run it?
Look at those numbers closely…
Freq scales but the bigger numbers are still the same when you turn them back down into smaller number just move the decimal.. this sequence of numbers is the extended much further or go back in the opposite direction to see what I’m talking about.
Horn response doesn’t even matter. At this point it’s a much bigger picture A concept that person must be grasp first. This is the big bang in chunks. Of number between it. Numerical reference to everything exist inside of that over and over again.
there’s no explaining it here people don’t get it And then I get the’ sin bin ‘ trying to explain it .
makes no sense, Administration or moderation whoever is in the way of anyone (people) trying to promote something new and unusual are the plunger in the toilet of Progress of DIYaudio currently.
Wake up and let you information flow it doesn’t matter if you understand or not..
(that’s not a reference to you at all GM, It’s the things I’d like to explain without worrying about being ‘banned’ By someone else)
it all sounds ludicrous because it’s impossible to put the pieces together when you’re being neutered already.
Only 430/860,1720,3440,6880,13760 are in hr at -990 dB.not sure , but i have spread this concept around into anything that cancels .13.5,27,54,108,216,432,864,1728,3456,6912,13824,27648…. 55296,110592,22184, 44368, 88736, ….
but 2580, 5160,… are as well. these numbers are all in 344.0 m/s not 345.6 where they would make more sense….
It might be important to look up the size of the moon and the sun precisely in the greatest possible detail wherever you can find i, in miles and in kilometers.
Numbers in mind for the rest of your life or simply recognize what they are in seconds let’s fit within time frames we know on earth already as 24 or 12 or six or 48 or 96 or three or .75 or .375 or .1875 hours? 186624 is speed of light in mikes per second almost perefrt(186xxx)
(432)^2 is 186624.,..
Do you think every single number as an 86491728 they combined in using the Pythagorean theorem to give you the location of things using the speed of light example is exactly a squared plus B squared equals C squareDo you think every single number as an 864 1728 they combined in using the Pythagorean theorem to give you the location of things using the speed of light:
a2 plus b2 is c2
e is mc2.
c is speed of light.
1728 is as well(square root of 3)
864 is ‘B
1728 is ‘C’
A is precise location of the earth twice a year when there’s about 12 seconds of day and 12 at night. 149.64918xxx
864 is 10 cm, 432 is2(20,200,2000000)
1728 is 5, 3456, 2.5, 6912 1.25 13824 is .0625, 27648 is 0.3125…,
All those numbers will be converted again to see something else.
22/7 is pi.
8/254 is pi.
Work it both directions.
22,44,88,176,352,704,1408,2816,5632,11264.
is it circles, or cm? 22,11,5.5,2.75,1.375(golden angle
Centimeters are circles its the diameter. Always has been because one centimeter is exactly one drop of freshwater anywhere on earth on the flat surface at any time.
And 1000 of those is a kilogram.
. Centimeters explains everything because it’s part of the meter and the speed of light is based on the meter and one second.
100cm is 39.37”
The speed of light was formerly based on 3937007874015748031496062992…
what’s the circumference of the earth is slightly more than 40000.0000000000000000000
does it matter that was still the basis of the speed of light update it again 2019?? not recently in a centimeter was changed to 2.54 (1950s) when originally it was a slightly less as well. 2.53999555???
all of that is why nobody understand a whole bunch of things and it’s very confusing.
But all of that shows up and clears up in a subwoofer because of sound and what’s required for putting it through wave length of the rectangle connection with the numbers is made if people would just stop and look at some other waBut all of that shows up and clears up in a subwoofer because of sound and what’s required for putting it through wave length of the rectangle.
Rectangle with a perimeter pie.
equals two pi R on circle well on a rectangle it’s like times width 2:1.
if you have a cube with a radius of one and a sphere in it displaces 52.38 by volume The virus fear equation with radius .5 and radius one point no show this as well very important ratio shows . Be cause that’s 30 and 240° on a circle also
30° is 5238 rad
that fits in a circle 12 times or pi divided by six is 180° at 3:06° are 31496 and 62992 in cms or 3.1428 and 6.2857142 in radian
and it’s still not the same as the number pi for whatever reason..
i’ve noticed no equation even barely uses the digits of pi beyond 314? So that’s where all of this stuff is missing and why would understand the connection I think??? Or was it supposed to be stupid and we only learn a limited amount and the educational system is limiting
Would you take two cubes that hold sperr inside and put them together as a 2:1 rectangle you have an entire another version of math pythago) within the diagnols of that rectangle from corner to corner which explains speed of light and breaking it down as well.
End up with hexagons on circles as a sine wave becoming harmonics on top of that circle already on its perimeter over and over again treating smaller smaller and more and more numbers too hard explain that’s why I draw things
I hope some of that makes sense , hard to catch all typos.Only 430/860,1720,3440,6880,13760 are in hr at -990 dB.
a2 plus b2 is c2
e is mc2.
864 is ‘B
1728 is ‘C’
22/7 is pi.
8/254 is pi.
100cm is 39.37”
30° is 5238 rad
Would you take two cubes that hold sperr inside and put them together as a rectangle you don’t have an entire another version of mass within the diagnosis of that rectangle from corner to corner which explains speed of light and breaking it down as well.
this is so far beyond subwoofers it’s ridiculous I don’t know that I even care about subwoofers anymore it’s taking me to places that are in everything including everything fixing everything!!
It started with the most screwed up subwoofer of all.. paraflex
roar
then odtl ml
(Bass reflex kissing cousin)
all share one thing in common
Sorry, no not really, though appreciate the effort. Curious though how this relates to fractals or is this its basis? IOW is our Universe just a huge fractal if one 'thinks' in 3D, i.e. as just one of the infinite? number of the supposed parallel Universes?
Given that most pysicalprcesses are chaotuic, it is not hard to map to a fractal.
dave
dave
I really wish that Tom Danley was still around in the DIY community. If you look at the synergy stuff and all the things that followed his trip to the pyramid and how they diverge from the tapped Horn pipe… It seems he’s doing the same exact thing as I’m doing however he’s actually using the physical shape of the angles and entering those into that pyramid shape.
All of those angles as they approach or are farther away from the mouth or throat depending on what driver I’ll have an interest income as well?
some point if you take 360° we pull it all apart and you just assign it to centimeters or radians Then you’re breaking it up into degrees which is the same thing that’s described we’re looking at the decimal points behind bythen you’re breaking it up into degrees which is the same thing that’s described we’re looking at the decimal points behind 1÷2.54 or 1meter/39.37” (393700787401574803149606299212…) parts that you don’t even glance at that you have to look for in your calculator…
those are preceded by more numbers and all they are is doubling up an angles in the equivalent numbers of pi and 22÷7
(22/7)/180 is (0.0174631746)
x _
176 is 30730158730
88 is 001536507936
44 is 768253968
22 is 38412698412
11 is 1.9206349206
5.5 is .960317460317
2.75 is .48015873015
1.375 is .240079365..
0.68.75 is .1200039625…
if /7
as 0.6875/7(5.625)
0982142857
1.375/7 (11.25)
1.9642857142
2.75(22.5)
0.392857142
5.5/7 (45)
.7857142
11/7(90)
1.57142847
22/7(180
3.142857
44/7(360
6.2857142
88(720
12.571428
176(1440)
25.142857
352/7(2880)
11264/7(1609.142857)
64 x25.142
But km/mile is 1.609344
inch to meter is 3937… (392847)
4.00000
-3936(7)
= .0064/( .0062992…) this is a repeat of the decimal points that were already been seen had to carry them out earlier as seen in the picture…
every single frequency at 344.0 versus 345.6 starting at 860 is 864
432 is 430
216 is 215
21600 is 21500(100 hz lost)
864 Hz is 10÷2.54. (10cm )
22 mm is 0.8661417322834645669291338582677165354(33070866141732…
all these decimal points that need to be pointed out in all these numbers carry-on like that and carry a sequence.
If you look at the numbers they’re just shy of the standard format 86If you look at the numbers they’re just shy of the standard format 864 (14) 1732(28)3464(56)6929(12)13858(24…
thats The diameter of the sun in miles followed by kilometers and then over and over and over again – but notice again the numbers have slightly changed but now we’re talking about the 7 inch pie because at 1The diameter of the sun in miles followed by kilometers and then over and over and over again – but notice again the numbers have slightly changed but now we’re talking about the 7 in pi.
As you can see and 11÷254 which is 433070866….
5.5/254
216…..
2.75/254
108.3
1375/254
54)1…
27)06..
(135)333
6)77667322834645669291338…
countdown using the sequence of frequencies we already know but this all starts at the radius and diameter of the moon
1079.6mile(108)
2159.2mike(216)6/360/21600
432(432.376)sun (12/720/43200
864(864752)sun 24/1440/86400
1728(1737)moon 48(2880/172800
3456(3464)moon 96/5760/345600
6912(695700)sun(192/11520/691100
13824(384/230400/1391400sun
abd big bang at this end.
x _
176 is 30730158730
88 is 001536507936
44 is 768253968
22 is 38412698412
11 is 1.9206349206
if /7
as 0.6875/7(5.625)
0982142857
1.375/7 (11.25)
1.9642857142
2.75(22.5)
0.392857142
5.5/7 (45)
.7857142
11/7(90)
1.57142847
22/7(180
3.142857
44/7(360
6.2857142
88(720
12.571428
176(1440)
25.142857
352/7(2880)
64 x25.142
4.00000
-3936(7)
432 is 430
216 is 215
5.5/254
216…..
2.75/254
108.3
1375/254
54)1…
27)06..
(135)333
1079.6mile(108)
Grab those patterns, Mess around with them however you thibk?
80/25.4 is 3.1496
22/7 is 3.142857
pi is 3.-141592
the sun is 3.15……
The speed of light is
(432)^2) is 186624(speed of light)
432.2(^4 is 349(offset driver entry any transmission line speaker) perfect fill in of the void and if you use a 300 cm transmission lin
300x.34906585(pi)
104.719755cm
349206349
10476190476cm
349986(8/254)
1049866cm
all of which when x3 are piz
314159/3
3142857/3
31496062992/3..
if you don’t carry the decimal points on these numbers you try to convert them strange things happen..
3937x254 is 99998(1/x )1.0000002000000040000800000160000032x10-6 always secret hiding in the reciprocal, Just like in decimal points
3937/254 15.5
1/254/254 155000310062000124000248000
(Easy conversion to use when building enclosures for 12 inch drivers because 15.5 “ times one “ is always 100 cm², 2 is 200, 3 “ is 300…. And So on. Works for big subwoofers and big TL s thank goodness I happen to bump into that at some point
80/25.4 is 3.1496
22/7 is 3.142857
pi is 3.-141592
the sun is 3.15……
300x.34906585(pi)
104.719755cm
349206349
10476190476cm
349986(8/254)
1049866cm
314159/3
3142857/3
31496062992/3..
3937/254 15.5
a2 plus b2 is c2
e = mC2
c is 3(9)
Sq rt 3 is 1728(1732)
864 Dispose the size of the sun diameter and also the exact amount of seconds in 24 hours on earth and if you use 1728SC squared and you use 864SB squared triangle lash drops dead center on the sun dead center on earth at 1496.49188(1 astronomicalnunit) As ‘
Get all those numbers squared and it’s even more fun
864(sq rt of 748)
X^2 as 746496
1728
as sqrt 299.2
^2 as 2985984
1496.48189 is 2239… A^2 in 30/60/90(29.9792457.759* ) if you look at 12 on 6.9375…
93.5,187,374,748,1496,2292
Pytgago
54/108
108/216(465656
216/432(186624(mikes/sec
432/864
864/1728(earth) radius of irbital mean
1728/3456
3456/6912
6912/13824(yes where that is?)
Now lok at
3937(187(.186666(3750/7)
7874(374(7500
15748(748(15000
31496(1496(30000(
62992….2992(6000
Keep going
Don’t forget all of these frequencies starting at 860 are donated completely gone(-990 dB)
And I can tweak it goes all the way back to 430 goes all way back to 216And I can tweak it goes all the way back to 430 goes all way back to 215
every single thing at 860 /1720/2580/3440(sound at 25m) 4300,5160(your angle of the pyramids of Egypt is 51.84(345.6 m/sec hz armt the same) ..6048,6912 7776,8640,9504,10…
a subwoofer set up this way all the way out to 19 780 the end of our response is 20 K..
They’re all -990 DB before and after not even a 10th of a hertz is already back up to 40 dB + and shoot straight back up to live..
and every single other one prior to that in the band width has a whisper and hint of it as soon as you move around the driver placement they appear as soon as you choke out one part of the closer they appear it’s a give-and-take and a logarithmic scale just like the solar system has the same thing occurring once you look at what those frequencies are including14620 (That’s leap year
e = mC2
c is 3(9)
864(sq rt of 748)
X^2 as 746496
1728
as sqrt 299.2
^2 as 2985984
Pytgago
54/108
108/216(465656
432/864
1728/3456
3456/6912
Now lok at
7874(374(7500
15748(748(15000
31496(1496(30000(
62992….2992(6000
Keep going
- Subwoofers
- 39 hz 4 x4 “ compound/parallel qw pipe.
