A very good question.Why me??
I defer to mchambin. 🤐
Entropy is defined by dS = dQ / T
Entropy increase is known as disorder increase.
I do not know how they prove this disorder bit.
I have totally forgotten my Thermodynamics!
I don't know why really, but I just checked my yellowing 1977 Physics Degree course documentation, and I have second year "PH212 FURTHER THERMODYNAMICS: LOW TEMPERATURE PHYSICS". 😀
3 Laws aren't there?
https://en.wikipedia.org/wiki/Entropy
I am pretty sure the arrangement of pieces on a Chess board has nothing to do with order and disorder. Because they have no Physical interaction to change the state of order or disorder.
One arrangement is as likely as any other. Just that we prefer the usual conventional starting position of the Black and White pieces. White's King on the right as White sees it.
However a box of fixed size containing Petrol and Air is not in equilibrium. It will catch fire eventually, and release Heat. And "Heat is Work and Work is Heat" as my good Physics teacher would frequently say.
But after that it should be in Equilibrium at a higher temperature. I think at that point, no increase in Entropy is possible unless you expand the box. It is closed system of fixed size in equilibrium. There is nothing more to know about it in Information terms.
You could also imagine a closed box containing water and a vacuum. The water can evaporate into a state of water and water vapour. Which I think would cool things down.
All very confusing. More study needed! 🙁
Order declines into Disorder in the long run. Why? Because we are not in a State of Equilibrium. This is a changing Universe.
I haven't really thought about Heat and Temperature and Energy for years, what with the recent worry about Germs and our Violent World and Climate Change and all that.
I am more interested in Information Theory as an Analog and Digital Filter Person: https://en.wikipedia.org/wiki/Information_theory
Which is actually a Thermodynamic Problem too.
Thermodynamics is an important problem we must address. As a rational Human Being, we should be asking our Energy and Climate Ministers if they understand the 3 Laws of Thermodynamics.
I bet they don't! Nor do the "Activists".
Everbody bangs on about Greenhouse Gases. Particularly Carbon (Carbon Dioxide) footprints. They ignore Nitrous Oxide and Methane and Water Vapour.
Still puzzling over my Water expanding into a Vacuum practical problem. Surely it must get Hotter? 🙁
I rest my
I rest my universe.Why is the word "order" used instead of energy or temperature?
I once again checked my BSc Physics Course Units! 🙂
I have a second year College qualification called "M211 Vector Algebra". Albeit only a 1/4 Course Unit out of the 12 units required. TBH, I was getting fed up with Maths at that stage.
I have always detested Physics Vectors and Axes. They only work in 3 dimensions.
Anyway, the Good News is Physics has made no significant advances since my 1977 days of studying it.
I am more Mathematics fundamentally. Consider the case of a young Carl Friedrich Gauss.
What is the Sum of the numbers from 1 to a 100. Solved it in a flash! 5050.
The Sum of an Arithmetic Progression. Thing is, he worked it out for himself.
Vishnaji, a strange contribution! I notice a symmetry of 8 words. Octos.
Surely the Latin word is verbatim. Never mind two glaring typographical errors.
Vebratium strikes again . And again he is wrong 😂
Space before interpunction is cringe fodder 🙂
What sort of Word is interpunction? Makes no sense to me. Also a lack of full-stop after fodder.
At least 2 mathematical errors in this statement. I won't go into the double forward slash. Probably more woolly thinking. 🙄
We are, after all, Professionals.
It should be noted that water vapor is an exceedingly potent greenhouse gas. However, it is transitory and lasts only for a few hours and therefore has a very specific function in the Earth’s overall temperature regulation mechanism. Not so CO2 of which 80% is removed in 100-200 yrs, but the remaining 20% hangs around for 200k plus years.
I believe Vishal is referring to Veritasium.
It's a channel of science and engineering videos, one of which was referred to a few pages back.
- Member Areas
- The Lounge
- What is the Universe expanding into..
