Space before interpunction is cringe fodder 🙂
Here's a translation for Steve, who I think spent his childhood in South Africa (see attachment):
"Leaving a space before a punctuation mark is cringe worthy."
TNT was referring to Vishal's act of leaving a space before the comma in his statement below:
Vebratium strikes again . And again he is wrong 😂
I hope this explanation helps reverse the entropy into which the thread is descending!
You could also imagine a closed box containing water and a vacuum. The water can evaporate into a state of water and water vapour. Which I think would cool things down.
Still puzzling over my Water expanding into a Vacuum practical problem. Surely it must get Hotter? 🙁
The boiling point of water depends on the pressure of the surounding air, and is 100 degrees celcius at normal atmospheric pressure.
At a reduced air pressure the water will boil at room temperature and begin to transform into invisible water vapour (water in gaseous form).
However, as the water vaporises it absorbs its latent heat of vaporisation from the remaining water. If there is only a little water involved, the cooling effect is dramatic and the remaining water freezes.
I believe this is the principle behind the 'freeze-drying' of fresh food.
Touché'.What sort of Word is interpunction? Makes no sense to me. Also a lack of full-stop after fodder.
At least 2 mathematical errors in this statement. I won't go into the double forward slash. Probably more woolly thinking. 🙄
We are, after all, Professionals.
Did I do good?
PS: https://en.wiktionary.org/wiki/interpunction
PPS: There where no math in my post 😉
PPS. In "new-time", a smiley is considered interpunction :-D
Can you point out for us where he is "wrong"?Vebratium strikes again . And again he is wrong 😂
correct.Here's a translation for Steve, who I think spent his childhood in South Africa (see attachment):
That's new to me so I investigated to find that, since emoticons are not used in formal writing, how they are punctuated is really just a matter of style choice.
Sometimes an emoticon can represent a terminal punctuation, like when it is used as an exclamation mark. For example, TNT believes in the Big Crunch 😱
When an emoticon is extraneous to the meaning of the sentence and can stand on its own, I would suggest ending the sentence properly with a period. For example, TNT makes a good point. 😎
ergoHave to admit - I made up that interpunction / smiley rule all by myself 🙂
Sorry...
correctThat's new to me so I investigated to find that, since emoticons are not used in formal writing, how they are punctuated is really just a matter of style choice.
eeeh... ergo i.e. "therefore" - cant catch the semantics here sorry...ergo
In that case, I am glad to have edumakated you!
fast forward to the next post.eeeh... ergo i.e. "therefore" - cant catch the semantics here sorry...
it's an inside out joke 😉
post # 9,090..you'll get it. 🙂... so you can see into the future ... spooky 🙂
He doesnot accept his mistake. Rather said " i doesnot go deep enough." deliberately hiding facts is not = not going deep enough . Thats fooling the audience. 15mw of energy he produce across the bulb and thats also considering 1s . If you consider 10 ns its even less . Nobody can see 10ns burst of 15mv . He just overballing the energy transfer . That light bulb will never glow for god sake . He just rebellious kid in the building that rebel against everyone and everything .
- Member Areas
- The Lounge
- What is the Universe expanding into..
