Aleph J was quiet- now it hums
New hum- any ideas?
I built the AJ over a year ago (2 maybe? can't track pandemic time anymore...) and have been enjoying it daily since. Last night, while it was on, I unplugged it from a source, and it make a loud noise. I now notice a hum in one channel, that wasn't there in the past. It's pretty loud- I can hear it during quieter music passages (or dialogue- I use it for my TV sound system).
I switched L and R speakers- seems like it's the amp. The hum is less when the that channel's input is disconnected.
Any ideas on what could've happened? I had followed many of the suggestions to reduce hum- balanced XLR inputs, short and twisted lead pairs, input lines kept away from power, etc. etc.
Thanks!
Thanks all- some follow up:
Unplugged at the source.
Different source: same issue.
When the one channel is fully unplugged, there's less of a noise.
It's actually progressively gotten worse- very loud noise- crackling/static + hum: now I unplug the speaker and source; just use one channel.
Perhaps start by replacing the JFETs? What other components might be sensitive to this sort of thing, and gotten damaged- the power MOSFETs? Is there some diagnostic I could run to see what's damaged...? I mean- clearly it's bad sounding. I just don't know if I need to re-stuff the board...?
Hi lonepine510,
Somehow the AJ input stage was exposed to a large input signal. Unplugging the source, even if one is not careful, should not cause any damage to an amp. It can cause damage to sensitive loudspeakers, though.
If you think about which transistors produce the voltage gain and are most likely to fail... the answer is the input diff pair. However, without checking a few basic things it is really hard to point you in the right direction - one that will get you to the root cause. For starters, you do have a good working amp PCB; so you could compare things.
I suppose the most important would be to ensure the current through output MOSFETs is within the normal range; to ensure they are not going to start overheating to a point where there' gonna be smoke. This is very unlikely, but it's always better to be safe than sorry.
Next, as others suggested, post the schematics and we'll tell you what voltage levels and voltage drops are correct.
Check the voltages as highlighted by 3 arrows...
The voltage drops across R16, R17, R18 and R19 should be around 0.35V (quiscent current 1.5A per each AMP PCB) to 0.47V (for the quiescent current of 2A per each AMP PCB).
Are you using balanced or unbalanced interconnects?
If using unbalanced, is the negative pin of XLR input shorted to ground properly?
Yes pretty sure it still is. Will double check with a meter.
Thank you!! Will check these out.
