Detailed PDF drawings for HiFi2000 chassis
Thank you Gianluca for the details!
Since there is no possibility to design a series of really matching products that include the 2U MiniDissipante as well as the Galaxy 2U ALU and end up with the same front panel height and width for all, I must now look for other solutions for my designs. It is very unfortunate indeed as the HiFi2000 chassis otherwise seem to be very good build quality and exterior finish.
Slim Line in 1U and 2U, Galaxy in 1U and 2U. Both with depth of 230 mm.
Thanks!
Here they are!
Do you have drawings of these panels should look like (holes, text..)? I can have a look at them and see how much it would cost to produce some of these but as I was telling you in my previous post they will be more expensive than standard panels because it's a customized job
Here they are!
Gianluca,
I have these drawings completed now. Where should I send them?
Bjorn
I have 2 questions on the Disspante chassis
  1. Is the aluminum bottom panel vented and if so is it 4 or 6 row? Are drawings available? The downloads on your site don't seem to show the top or bottom panels. I'm specifically looking for the middle distance between the rows for the bottom panel.
  2. For the 300mm heatsink brackets, are the screw holes that mount the bracket to the heatsink 100mm part? The drawings are for the 400mm brackets and seem to show 100mm spacing. Wasn't sure if the 300mm brackets have the same spacing.
Thanks!
I know this is a bit late but I have 3D models of some of the cabinets I made from the dxf drawings. I use Solidworks but can save in a variety of format. I can also generate a 3D drawing which you can screen shot the different panels and draw and dimension features in PowerPoint. Let me know
