Jolida SD/SJ 202a …. Looking for an output transformer or substitute of same dimensions.
Hi guys, I managed to blow my right output transformer on my Jolida SJ/202a int amp.
it is a 40wpc, EL34 tube amp.
Does anyone know of a correct substitute for this amp?
I called Mike Allen of Jolida, but no stock available.
My technician is finding a challenge in sourcing one of the correct size.
The dimensions are 3 3/4”t x 2 9/16”w x 2 11/16 d
You could take the old frame off the faulty transformer and put one of these https://uk.rs-online.com/web/p/audio-transformers/1237237?tpr=1 inside or get the transformer rewound.
Nothing special about them.
40W per channel is a very hopeful figure if it is a HiFi amplifier. A pair of EL34s in UL mode will produce about 22 Watts RMS at less than 5% THD. 40 Watts at almost 18% THD.
Thank you, but wouldn’t that be out of spec if the left channel remains @40watts?
how will that fit in the existing frame.
I‘ll send you a pic.
  • Any Scanner_05_01_2022.pdf
