An ODD tonearm design.
Account Closed
Joined 2018
Something for others to Chew On.....
It would seem to me that a design like this was never investigated, but would seem to correct and even eliminate the known pivoted tonearm issues
Thoughts?
Thoughts?
Hi wiseoldtech,
As you seem to be a knowledgeable individual, it doesn't make sense that you would post something like that.
Sincerely,
Ralf
Hi wiseoldtech,
Sincerely,
Ralf
Well, I'm curious about the forces involved when playing a record - the centrifical generated "pull" on the arm from stylus drag, and the above geometry which would seem to cancel that effect.
The more the "pull", the more the arm would "tend" to drift outward, instead of inward.
And the horizontal pivot, causing the arm to move "rearward" as it moves along the record, maintaining good alignment of the stylus.
Interesting design. Its good to have different ideas. I guess if the headshell is straight, the design (because Stlus drag) would somewhat compensate for inward force. If we apply string test one can imagine it. How much advantageous or counterproductive ? only building and changing dimensions of various segments can tell.
I think first mention of separate vertical and horizontal pivots (and different design) was from Mr. David Read (Wireless world November 1980). However the tonearm segments position was on opposite side and goal was different.
regards
The 'novel design' is just a traditional tonearm (drawn in red)
Reactions: mikey_audiogeek
Do explain why.
I'm sure it would be interesting.
Nonetheless, my main turntable is a linear tracker, so no worries of antiskating and alignment.
Draw a line through the length of the cartridge cantilever and past the tone arm pivot. That’s the direction of the force vector from stylus drag.
Now, draw another line perpendicular to that one and through the tone arm pivot. The length of that line is the torque arm.
That’s your force vector diagram. It does not change based on the shape of the tone arm. Only the pivot to stylus distance and the cartridge offset angle matter.
Reactions: alighiszem
It's traditional in the sense that it has an offset headshell.
However, you're not seeing the fact that since the actual connection of the arm tube is to the left of the horizontal pivot point.
A "pull" at the stylus end would create a force that would tend to make the horizontal pivot turn anti-clockwise.
