HI Art+/-3dB, close enough for rock & roll ;^).
The deep notch at 180Hz is interesting, looks like the plenum and port output may be 180 degree out of phase at that frequency, usually that sort of dip would show up in the simulation. That said, Hornresp is assuming one port, but there are four, so the port's "pipe resonance" will not be the same.
Some interesting discussion in this thread:
https://techtalk.parts-express.com/...5-port-resonance-what-should-i-be-looking-for
If the ports are capped off (covered/stuffed), does that dip still show up in the response?
Cabinets are finished!
unfortunately with 4 ports there wasn't space enough and the pipes went against the cone baskets.
If the weather allows me tomorrow I will test the whole pa at high spl in free field and check if the dip disappear!
I need to assemble dsp blocks on my audia solo 8x8.
I would to insert rms compressor and peak limiters (not a real limiter but the same comp with 100:1 ratio and 0.1ms attack possibly) each channel.
The rig is:
sinbosen k450 4x450 at 8ohm for the 2 channel of dcx464-8
proel psw2600 2x1300rms at 4ohm for 2xrcfmb12n351-8 wired in parallel per channel
sinbosen fp14000 2x2400rms at 8ohm for 1 18115-8 per channel.
How I can adjust limiters in the dsp to have good performance and safety ?
this powersoft manual is xhaustive?
Thank you very much
I can't think of anything not already covered in the Powersoft manual to help you further with adjustment of peak and long term (thermal) limiters.How I can adjust limiters in the dsp to have good performance and safety ?
hi guys
Finally tested the complete system in a free field😀
what I found is :
.the synergies tops are really really impressive: I don't remember a small PA with this sound quality in the details, dynamic, pattern control, low self noise, and power capabilites. at highish spl at 20meters I lowered the highs few dbs maybe for Fletcher-Munson curves even if in Smaart there was flat respone.
. I'm happy also for the sub, big punch and spl but I had 4 considerations:
1-with secondary flare installed I could see by eyes the bottom and top panel vibrating +/-5mm and so the extension was jumping on the floor causing unwanted noise. I would add a removable vertical bracing in the middle.
2-i had some noise without extension also: the boxes are glued and screwed (around 200 5x40mm wood screws) It is possible the screws cause rattling noise?I think yes so I wil try removing.
3-I also covered the internal sides of the port with open texture tnt tissue only for procecting the cones from the dust. Is not recommended to cover the ports like I did?
4-the sub drives(8ohm each) are wired 1 for fp14000 channel,doubled mono signal from the dsp. with -4db leds flickering witch 7mm (by eyes) excursion
can I achieve high spl running drivers in parallel 4 ohm and fp in bridge mode?
(with sub at same volume of the tops, the tops amps weren't even flickering the signal leds almost).
my doubt is also that covering br ports lowered the max sub spl.
here some system pictures in my car box.
Thank you
Ale
what I found is :
Thank you
Ale
Hi I forgot to mention that I tested also without handles!Those sprung handles are much more likely to rattle than the woodscrews.
Ale
The only way screws would rattle is if they split plys apart in the plywood. Run a slow sine wave sweep to find the frequency that causes the rattles, then use a cardioid microphone (cut the low frequency) through headphones to listen closely to what is rattling. Might be the port supports.2-i had some noise without extension also: the boxes are glued and screwed (around 200 5x40mm wood screws) It is possible the screws cause rattling noise?
If the cloth is breathable (like speaker cloth) it should have no effect on output.3-I also covered the internal sides of the port with open texture tnt tissue only for procecting the cones from the dust. Is not recommended to cover the ports like I did?
You were using around 1100 watts if you had 4dB left.4-the sub drives(8ohm each) are wired 1 for fp14000 channel,doubled mono signal from the dsp. with -4db leds flickering witch 7mm (by eyes) excursion
"By eye" usually means peak to peak, which would only be 3.5mm one way. Not much excursion.
7mm one way would be only around half Xmax, which means another 6dB before running out excursion, a couple dB more than the 4dB you had left.
Going from 2350 watts per driver to 7000 would definitely get the cones jumping, you would need to limit the RMS power way down from that.
Art
its normal to apply EQ from flat, it depends a bit on taste, music genre and the acoustics of the environment you are in but generally there is:.the synergies tops are really really impressive: I don't remember a small PA with this sound quality in the details, dynamic, pattern control, low self noise, and power capabilites. at highish spl at 20meters I lowered the highs few dbs maybe for Fletcher-Munson curves even if in Smaart there was flat respone.
1) bass boost below 100Hz, this can be >+10dB
2) overall spectral tilt so that the highs are reduced
3) perhaps a cut around 2.6kHz due to the ear canal resonance
There is a lot written about target curves for small rooms in the home but in larger spaces and at higher SPL and with varying intrinsic EQ to recorded music there isn't a unaversaly applicable target curve. I tend to basically contour the system and correct room modes in the processor and then apply additional bass boost and any cuts to reduce harshness on the desk.
My response to post #20 below
I guess some scripture was left or dropped off by accident when "they" were exploring our planet.
Then somebody found them in ancient times and built the pyramids.
Centuries later more forgotten "notes" from the space engineers were left...
Somebody found them and.....ohhh the tapped horn ....
And I can go ...on...and on...🤣
Only God knows! 😉 Me, I'm still 'scratching my head' as to how Pi, etc., math constants? were found or the incredible accuracy of ancient complex structures, etc., were designed built without falling back on space aliens
https://www.prosoundweb.com/the-gre...AJG-A-fXuWs5UVE_RatnFz9_T9HuvSPrC9grgEIdj9x4P
didn’t Tom start the multiple entry stuff after this trip?
(I was using a lot of psylicybin and mdma when I first learned horn response 🤓 and some of my ridiculous posts about planets and numerology reflect it 🙈) … embarrassed….
- Subwoofers
- Unorthodox 2x18 slot loaded PA sub
