audio cables
Amplifiers can be sensitive to the load, which includes the wire. Some amplifiers may burst into oscillation
when loaded with excessive capacitance. Also, series impedance in the speaker wire will interact
with the speaker system, in a similar way as the amplifier's output impedance does, causing
frequency response aberrations.
Reactions: Jcris and krivium
Some amps are sensitive to the load - I call them poorly designed but that's just my opinion.
I stand by my former comments that the average person wouldn't hear a difference between those seventeen-thousand-quid interconnects and barbed wire...
I've run my amp using single wire signal (earth return) and nobody noticed the difference!
Reactions: MrKlinky
Hi-Fi News' rule of thumb is that you should allocate 10% of your budget to cables.
By that measure, only owners of systems worth in excess of £127,000 need apply.
If you can afford that much for your system, why not strew it with cable jewellery!
Reactions: academia50
That review fails at the first sentence
Cable aficionados will already know that the best insulation is no insulation at all, with air (in lieu of a vacuum) providing the best and most cost-effective dielectric
The cable itself meets a lot of the tick boxes for high end audio. Expensive, exotic metals, delicate etc, but I can't see it meets any of the known figures of merit for a single ended interconnect (which is also a big plus for some high end stuff). So all absolutely what we would expect.
Hi-Fi World magazine (not to be confused with Hi-Fi News) exhibits a refreshing honesty to the contentious and highly subjective area of cable reviews.
In his review of mains cables that cost in the region of £2k, Martin Pipe sensibly concludes “If you have a high-end system, give the (cables) a trial. If you hear no difference, don’t buy them. It’s as simple as that.
And "If you hear it, it's psychosomatic"...
