Sansui AU-X11 oscillation
I repaired a channel in this amp using T03P outputs ( 2SA2223a & 2SC6145A) and replaced the blown drivers with Toshiba TTA004B & TTC004B.
Its up and running, but I'm getting oscillations looking at a square wave at 10kHz .
I tried adding 47pf caps to the drivers with no luck... Should I be adding some caps to the outputs as well??
Its up and running, but I'm getting oscillations looking at a square wave at 10mhz .
I should add, I replaced Q 4&5 and Q 11&12 with KSC 3503/ A1381.
I have simulated au-x1 not the x11 but I think they maybe similar designs. I think the compensation network needs some slight increase in capacitance to settle down the ringing. Iirc there was a case on Audiokarma where we worked out a solution, it was in the Sansui section
Its in the VAS that you require extra compensation,
if I refer to AU-X1 schematic, it would be adding starting from 10+pF increasing as required for stability and the 10Khz square wave test,
add across C09,C10 (3p) the b-c of Tr10,11, which form the push-pull VoltageAmpStage.
Nice. Thanks, very helpful!!
I replaced these transistors on this channel with the a1381/c3503 , could this be part of the issue?
I notice that the c3503/a1381 have a very low Cob? I also have ksc2690ay and ksa1220 on hand? Worth a try?
