How to convert single ended audio signal into differential signal (single power supply)
I made an amplifier, which is a differential audio input, but my sound source is a single ended signal
Is there a simple circuit that can convert a single ended signal into a differential signal?
Simplest solution: connect the positive input to the output and the negative input to the ground of the source. Also connect the shield to the ground of the source, insert a physically small 100 nF capacitor in parallel with a 100 ohm resistor between the shield and the ground of the source if you get hum.
Simplest solution is balancing transformer. Just like i did for F1J. Its fully balanced amplifier, and many feed it with unbalaced signal by grounding one input.
My solution was small balacing transformer. Exactly the same one as dartzeel uses. Input signal is small, so this trafo is very small.
You can find link in F1J thread.
When I wrote post #4, I assumed a differential input with a reasonable common-mode signal handling and common-mode rejection. Please ignore post #4 if there is little or no common-mode rejection, like when you use two identical amplifiers driven in antiphase as a bridged amplifier.
Thank you for answering my question.
As you said, if you use the method you proposed before, my amplifier will make a lot of noise...
I've been playing around with the attached circuit lately and I'm very happy with the way it performs. I sim'd it with a TL072, but a higher quality op-amp will give even better results.
Reactions: jaycee
There must be something wrong with your noise simulation set-up then; a 40 nV/sqrt(Hz) noise source added to an 18 nV/sqrt(Hz) op-amp should be quite noticeable. Unfortunately I can't tell what is wrong from the screenshot. How do you define the output and input quantities for the noise analysis? Do resistors in your simulator produce thermal noise by default, like they do in SPICE and Spectre?
Reactions: theAnonymous1
I'm using TINA-TI but don't have much experience with it. From what I can find, it does model Johnson noise by default. Noise analysis was 20Hz-20kHz with an S/N signal amplitude of 1.
EDIT: Ok, it was just something weird going on with the program. Now when I change R6 to 0 the noise figures lower by more than half.
