Hello everyone!
I am having trouble running simulation schematics that I created using LTspice. I used external code for the NE5532 opamp from this website: https://jeastham.blogspot.com/2011/11/adding-ne5532-op-amp-model-to-ltspice.html
For some reason the simulation does not appear to be working. There are no errors thrown, but the output signal comes out as a very small voltage.
I am new to this
Any help would be greatly appreciated!
Pavlo
I am new to this
Pavlo
Looking at the .png file, it looks like you are driving it with a common-mode rather than a differential signal.
That fixed it! Thank you!You should include a "ac" voltage for the signal sources (in advanced settings).
Or add 180 as AC phase to one.It is correct for how the sim is set up.
Two inputs, one 180 degrees out of phase but that doesn't apply to the '1' you added. Try making one of the AC Amplitudes a -1
Thank you! That worked!
I'm not so sure that works for AC analysis. AC analysis does not even need the voltage sources setting up, you can set them as 'None' and just enter 1 and -1 for the Small Signal AC AnalysisOr add 180 as phase to one.
I edited my post. I meant add 180 as AC phase. That is meant for ac analysis.I'm not so sure that works for AC analysis. AC analysis does not even need the voltage sources setting up, you can set them as 'None' and just enter 1 and -1 for the Small Signal AC Analysis
Here are all files with everything seems to be working correctly.
Attached is also NE5532 zipped model file - to be placed into ...\Documents\LTspiceXVII\lib\sub
This would work:
But this I don't think will. The '1' needs to be a '-1':
AC phase 180, AC value -1 or one source turned upside down should all work.
Oh that one 😀 There are just so many ways to do the same thing in LT.You are still missing the "AC Phase" field. That is below the "AC Amplitude"
Surely you only need one voltage source anyway, just float it, there are DC bias resistors so it's not a problem.
- Design & Build
- Software Tools
- LTspice simulation for the instrumentation balanced input using NE5532
