LTspice simulation for the instrumentation balanced input using NE5532
Joined 2011
Hello everyone!
I am having trouble running simulation schematics that I created using LTspice. I used external code for the NE5532 opamp from this website: https://jeastham.blogspot.com/2011/11/adding-ne5532-op-amp-model-to-ltspice.html
For some reason the simulation does not appear to be working. There are no errors thrown, but the output signal comes out as a very small voltage.
I am new to this
Any help would be greatly appreciated!
Pavlo
  • instrumentation-amp-r1.0.asc
Not sure why, but the frequency response on the output looks horrible. I is totally fine before on the input of the last opamp.
Here are all files with everything seems to be working correctly.
Attached is also NE5532 zipped model file - to be placed into ...\Documents\LTspiceXVII\lib\sub
