Eimac 100TH SE
few months ago i was to ETF european triode festival in France
VinylSavor: ETF 2018 in France
and the shootout was win by Gilles we discover the wonderfull sound of power grid transmitting dht triode 100TH
i just fall in love!
these triodes need 24H heather a year to be safe
the best of thems are eimac wings plate tantalum platinium thorium etc
http://www.tubecollectors.org/eimac/archives/150t.pdf
the proto amp i build sound fantastic input stage 6SN7 and CF choke loaded driver parallel 6BX7 direct coupled to 100TH grid
enjoy
Reactions: TR00
this was the starting point ended with 6BX7 and mosfet regulated +B +- 300V fixing 100TH bias
also try this attached schematics but the initial simplest do perfectly the job
should not push to 100Watts SE for tube life these are pulse triodes
Hello all !
I just finished two 100TH monoblocks and the sound is amasing, power and clarity from highs to lows without fatigue.
Far away from a tubby sound !
The power is 20 watts rms.
Some pics :
Reactions: TR00
Beautiful, félicitations ! 👍 IMO nothing beats the looks of that spherical bottle & magnificent light.
Does any of you 100th builders have an opinion on Lewis & Kaufman JAN-CBOP-100TH ? They are available locally. I'm slowly gathering parts for a build myself.
Hello, I have some L&K 100TH, they are ok and thé sound is perhaps a little less refined vs wings Eimac,
usually they polarise hotter than Eimac in same circuit .
I had one faultly but you always need more 100TH you need because some are bad by all makers.
This is VT "porn" at its best - thanks for making me feel what it's like to "want" again ;') Look but dont touch!
Behold a whole new market: When the blue pills fail, turn on the blue lights :bigeyes:
Thank you Gillou, I'll try my luck with them.
@claudiomas: Are you still running them at 1.1kv & 90mA with Toroidy TTG-EL34SE?
Those sound like an economical solution & I'm happy with their stuff so far.
Simon
Simon
this amp still running but with SV572/160 , the TL304SE run with four 100TH, two in parallel each channel
https://www.diyaudio.com/community/threads/se-304tl.347284/#post-6840736
  • Thank You
Reactions: Klimon
