15 inches are for "Royal fireworks"Perfect for Händel's "Water music"...![]()
So ya wanna hang out with SLOBs? Still spaces available to assemble your own pair!
Drivers, crossovers, prefinished wood baffles and base.
SLOBber over this:
https://www.diyaudio.com/community/...2022-northern-california.384670/#post-6981882
See you there! NP will be there too! Observers welcome, make it a party! Overnight camping allowed!
SLOBber over this:
Pep, I got my chassis yesterday, thanks for that. What pots did you use on the front panel? Thanks Bubba
This:
https://www.mouser.it/ProductDetail/774-270X232A253B1A1
It's a 0.125" shaft. I wanted to use those knobs salvaged from a very old mixer...
Beautiful! Makes me wanna build one!
Hi all,
As I'm building a little 24V linear psu for this project, I'm considering to use a second socket to feed the B1R2 (that will become B1T once Edcors arrive) since LT1084 is powerful enough. Is a 16VA xformer a right choice or better go for 30VA? Thanks
there is no replacement for displacement?
Mini Cooper got its share of Monte Carlo Rally
so, conclusion - best to have at least 500VA EI chunk, close to those signal xformers
disclaimer - in case of Iron Pre, with Good Gemini regs - there is no difference , as long you use decent xformer with enough VA (10VA)
for Peppennino's build of B1T, dunno what reg is used, so maybe it's best to go with 500VA
- Papa’s slot loaded open baffle version #2
