TPA3251d2
ok i'unterstand!
For a hi -end dac dac ,it's normal.1656 is for symetrique signal....
but it's impossible to have a symetrique signal whith a single op amp...
and 1656 for symetrique...opa16111 asymetrique .
have a nice day!
Hi Danny.
You can't replace the two dual Op-Amps with a Single Op-Amp. The pin out is different for a start and I am quite sure that both the the Op Amps are used for each channel !
James
YES ...🙂
Received Aiyima A04 green board. Replaced thermal paste with Arctic MX-4. Tilear HD325x Rev: 2.1 is written under the radiator. Replaced 10mF capacitors with Elna rbd 10mFx25V. At the exit of Nichicon FW. Then I will put the original Epcos 0.68 mF MKP. The op amps are not like the original. Temporarily installed from another device. I will change to OPA2132PA.
Well done, looking forward to know how it sounds )
Updating the inductors should be a good choice as well...
appologizies if this isn't the appropriate thread, but I've been looking for a acceptable psu for my tpa3241d2 amp.
Looking for a 36v 12-30 amp PSU without a fan, preferably SMPS. Looking for making a portable speaker.
You can try the Mean Well LRS-150-24 https://www.audiosciencereview.com/...ni-liquid-music-system-with-aiyima-a04.31435/. It's small, quiet, affordable, and certainly capable of taking the TPA3251 to the limit of its power on an amp like the A04.
