Gas prices
the real fraud is believing we can go on like this with fossil fuel forever.
That won't be possible either way because it will run out. Even those believers know that too.
That is the attitude of the greens in Germany who spread this onto the French greens.
It spread much further than that. US has plenty of those too.
In the future a must key to breeder reactors.
Thorium in the near future maybe?
as a german I think I should be proud of beeing the scum of the earth.
Just think of how many Hollywood blockbusters would not have been as successfull without the germans beeing the bad guys. StarWars/DarthVader to name just one.
And when You run out of sensible arguments in a discussion You can always tell a german to be a Nazi and You'll win. Isn't that great?
Over time though this lost on esprit and something new, something different was needed.
Beeing quite the inventive ******** we are, we now have come up with something new, something even more evil, since it camouflages as beeing good .... the 'German Greens'!
We now not only cover the past evil but also the future evil.
Like Nazism the Greenism is a infectous ideology .... it already spread around .... France, the US, China and many countries more.
Master Yoghurt would say: "Be aware! The Green Force evil it is. Don't let yourself fall to the Green side. The Green You must resist. Your nuclear Power at Your hand is. Find Your fossile friends for help. Be the waste with You."
jauu
Calvin
Huh? Star Wars / Darth Vader plots have roots in German history? 🤨 🤔
Around here, people typically associate green with Irish, especially last week. In other times, this.
Russian woman on youtube, said gas is up,
to about $2, per gallon, in Russia.
Can´t vouch for a YT video, but just checked:
https://www.globalpetrolprices.com/Russia/gasoline_prices/
It was 1.642 U$/gal one week ago, so "almost reaching U$2" looks reasonable.
It's a natural reaction from our prevailing world paradigm to dismiss those over-unity generator videos as a hoax, but it would be prudent to also come up with an explanation on how they did carry out the stunt trick.
The only explanation I can come up with is that the connection box on top of the motor and the phase cap (which isn't actually required when an external force is helping to start the motor in any direction as required) on the side could hold a battery and some circuit the feeds the motor, the thick bottom plate could be hollow and hold much more but there are no visible cables running from it.
At 19:43 the presumable patent is flashed, but the registration number is obscured, Tineye couldn't, or doesn't want to show anything.
(Free energy source by combining two power generators - 14 May 1967 WIPO PCT)
Free energy source by combining two power generators 14 May 1967 WIPO PCT https---i.imgur.com-...gif
Picture source: https://imgur.com/CXO8FEn
I have mentioned the Star Wars series has drawn on some aspects of Hinduism, including thought projection and cremation of dead bodies as a method of disposal.
I will not comment on German thinking processes, we have many politicians in India who are known for confusing statements.
Milo Minderbinder is a perfect name for some of them.
Here we had a Narmada Dam project, which was stalled by people who were receiving foreign funds. When asked for an explanation, they ran away. In 1995 or so.
So if the Russians influenced the German public through Greenpeace that gas was a better alternative, compared to nuclear, in order that the country become dependent on Russian gas, rather than nuclear, I can only say the Greenpeace people were perhaps corrupt.
But bearing in mind that the country is densely populated, and a nuclear accident would be a disaster, maybe the Germans decided to abandon the projects for public safety reasons.
They could have had plants built by the French near their borders, and France has a good safety record in nuclear power.
That was a possible alternative, but like I said, I do not keep track of events there.
India has been trying to build Thorium reactors, still at final trial stage for the last decade.
There was an experimental one with liquid sodium cooling, which itself is dangerous...
I hope that this is not too far off topic.
OK all you clever people, why are the turbine blades on modern large wind turbines so narrow? It always seems to me that 95%+ of the wind just goes straight past. Are the smaller tree like multi fan setups able to produce more electricity for a given SQ M of blade span?
Thanks.
Beware: The "renewable" mantra is a fraud.
Most is intermittent + unpredictable + non storable.
This has huge consequences.
Whilst storage is an issue, for now at least, renewables can be a major source of energy generation. Overlapping forms of generation, or a country wide energy sharing plan would no doubt help.
https://en.winddenmark.dk/wind-in-denmark/current-energy-production
Today wind generation in Denmark is at 101% of need, yesterday it was only at 27.5%.
It's not like the wind 'pushes' the blade to make it turn. The force that makes the blades spin is generated just like the force generated on an airplane wing.
Due to the wing/blade profile, the air pathlength on one side is different from the other side. Since the wind going over one side of the blade/wing needs to join the other side mass at the same time, the wind on the longer pathway needs to speed up. That results in lower air pressure on that side, so the blade/wing gets pushed by the difference in air pressure between the two sides.
That generates the force.
So it's a complex function of wind speed, blade/wing profile and rotational speed (airspeed for a plane).
That's the reason why windmill blades are changing their angle and rotation speed with windspeed, to prevent damage while still maintain generating efficiency.
Jan
Actually blade design is taught in Fluid Mechanics, and like above, in a real life situation, variable pitch blades are needed.
You can learn a lot about this by reading about propellers / air screws in aircraft, the new scimitar shapes are quite different.
Windmills have systems to protect the blades during stormy weather, excess wind speed and also during maintenance.
The newest wind turbines in off shore North Sea are also a newer design.
Nuclear energy is the safest.
Three Miles Island: 0 death, 0 injured
Tchernobyl: 53 proven death, controversy on later effects, unproven injuries.
Fukushima: 0 death, 0 injured.
Tchernobyl could not happen ever in France for several reasons.
The Tchernobyl reactor was graphite gas, an abandoned technology. It was notoriously known to have stability issues. So had to be run with tigher procedures. It had no confinement building.
The Soviets did all wrong. They ran a test to see what was to happen breaking procedures, were ordered to do so. What had to happen, did happen. After it blew up, it took them a week to evacuate people.
At Fukushima, the confinement building held for days before releasing crap in the environment. People had been evacuated already from the very beginning.
At TMI the confinement building kept the crap inside, nothing was released in the environment.
I make it short, but with no bias on realities.
All can be checked and detailed.
Reactions: JMFahey
Americans on average live in much larger cities compared to their european counterparts, therefore they have to drive quite a bit longer for their work commutes. Most americans don't have the luxuries of "riding on a bike" to work as in europe.
Wow, this is as backwards as it can be! Why would larger cities mean longer commutes? And why can't they ride a bike?
Yes, I did spend time in the US. Several times. At different places. Long Story short: people in the US are just used to use a car for EVERYTHING once they leave their their house.
Reactions: JMFahey
Chernobyl was a controlled disaster, it seems they ran a test (which was to be done in the day) at 2 AM, and the night shift operators were new on the job.
This could have happened in a coal plant.
Radiation sickness and cancer induced deaths from Chernobyl...that is a subject that will ask the moderators to view it as a political post.
You can read up elsewhere, information is available, bias is also possible.
Americans had Metro /light rail systems in place since the 1930s...yet the suburbs exploded.
Cheap fuel, a relatively high income, and suburban life...30 year mortgage at 4% was unheard of in the rest of the world.
So people moved out of the cities.
Bear in mind also that a lot of this happened after WWII, and a lot of people moved to the then new fields of defense and civilian aircraft manufacturing.
Families shifted from the Eastern states to the new areas like Burbank, Seattle and so on.
Today you have very high real estate prices in the cities worth living in, and crime rates in some other places are beyond belief.
Hopefully, the Covid pandemic taught people to be frugal..and how to travel less.
In India, they seem to be celebrating being released from jail after the lock downs...
