Gas prices
My Venge Vias has taken on a new meaning all of a sudden !
Reactions: daqvin_carter
That's because everything is spread out. Most American cities no longer have stores and eateries within walking distance of residential area (blame the 50's & 60's urban renewal projects).
I grew up in the inner city and there were corner grocery stores every few blocks. These weren't like the current convenience stores, they had fresh produce and fresh meat. The owners worked there and knew all of their customers by name. This was a working class, blue collar neighborhood and most people took the bus or train to work. Just about everything you needed to live a good life was in walking distance. Most of my teenage friends did not have cars, we rode our bicycles in the spring, summer and fall and took the bus or train in the winter. I still live in the inner city and get around pretty much the same way as when i was a teen, I only drive when necessary. Unfortunately, most Americans cannot live this way. "Big Box" stores have replaced corner stores and are only accessible to most by car.
Reactions: JMFahey and kevinkr
2011 I was working on a large building site, one day posters went up...
USE CORDLESS POWER TOOLS WHERE POSSIBLE
yeh right 🙂
That is what a brace and bit are good for.
The auger bits are still quite common. The biggest issue is knowing how to sharpen them.
Not only are there the common brace type drills, I even have an “electricians” drill. Ever wonder how they got holes to wire places when a hand brace couldn’t swing it?
Reactions: bedrock602
You wouldn't catch me swimming in L. Erie or L. Ontario for that matter.
Zebra mussels and restructured storm drains appear to have remedied much of that. Lake Ontario is remarkably clear most of the year and Toronto beaches haven't closed in ages. Then again I'm old enough to recall when the Erie shoreline was a continuous carpet of dead fish due to the phosphates.
Reactions: kodabmx
With electricity you can choose how to generate it. Wind, sun, hydro, it is possible. With fossil fuel there is no choice. Earth is not happy.
But the main issue is how much of it comes from what source. When you look at how much electric is supplied from wind and sun vs. fossil fuel, especially how much investment is put into those, it may change your perspective, unless you already went through it.
Electric is nice if you live in Québec:
  • In 2018, Quebec generated 213.7 terawatt hours (TW.h) of electricity, which is approximately one third of total Canadian generation. Quebec is the largest producer of electricity in Canada and has a generating capacity of 46 176 megawatts (MW).
  • With over 40 853 MW of installed capacity, hydroelectric stations generate about 95% of Quebec’s electricity. This includes Canada’s largest hydroelectric power plant, the 5 616 MW Robert-Bourassa facility in northern Quebec, which is currently under rehabilitation until 2022. Another major hydroelectric station, the Romaine Complex, is currently under construction on the La Romaine River in Côte-Nord. When completed, it will have a capacity of 1 550 MW from four generating stations. Romaine-1 (270 MW), Romaine-2 (640 MW), and Romaine-3 (395 MW) are already in-service. The final station, Romaine-4 with 245 MW capacity is expected to be online in 2021.
  • Wind is the 2nd largest source of electricity generation in Quebec. In 2018, wind capacity reached 4 096 MW and accounted for 4% of the province’s generating capacity. The last wind farm to be commissioned was Mont Sainte-Marguerite, with a generating capacity of 143 MW in March 2018. The 225 MW Nicolas-Riou wind farm was also commissioned in 2018.
  • Other sources of electricity generation include natural gas (mainly for peak winter demand), diesel (for power in remote communities), and biomass.
Ontario isn't bad, either:
  • In 2018, Ontario generated 151 terawatt hours (TW.h) of electricity, which is approximately 23% of total Canadian generation. Ontario is the 2nd largest producer of electricity in Canada and has a generating capacity of 40 671 megawatts (MW).
  • In 2018, about 96% of electricity in Ontario is produced from zero-carbon emitting sources: 60% from nuclear, 26% from hydroelectricity, 7% from wind, and 2% from solar. The remainder is primarily from natural gas, with some biomass. Ontario’s electricity generating capacity is primarily located in the southern portion of the province with significant hydro generating stations located in eastern Ontario in the Ottawa River basin and northeastern Ontario in the Moose River basin.
  • Three nuclear power plants with a combined 12 633 MW of installed capacity provide the bulk of Ontario’s baseload generation. Bruce Power on the east shore of Lake Huron is the largest, with eight generation units and a capacity of about 6 600 MW. It is one of the largest nuclear power plants currently operating in the world.
  • Ontario has over 200 hydroelectricity generation facilities with a total capacity of
    9 251 MW.
  • Ontario leads Canada in wind capacity. About 5 061 MW of wind capacity was added between 2005 and 2018.
  • About 98% of solar capacity in Canada is installed in Ontario. In 2018, solar in Ontario had a total capacity of 2 871 MW.
  • Ontario has the largest 100% biomass-fueled plant in North America. The 205 MW Atikokan Generating Station was converted from coal in 2014.
The main difference is cost: Ontario power is almost twice the price as in Québec.
https://www.eia.gov/tools/faqs/faq.php?id=427&t=3
As most charging is done at off peak times, less comes from combustion. Natural gas is the popular peaker power source as start up times are quite fast. As hydro is constant coal power is also adjusted downward as demand drops. Wind is maximum usually at dusk and dawn.
Even in the US coal is under 22% for all electric generation and dropping.
Someone did say that in that in the end, an electric car is a coal powered car, as the electricity came from burning coal...
Where did you pull that weird idea from?
Coal is the worst fossil fuel available, much shunned all over the World and only used out of desperation or by Countries who favor Industry at all costs and couldn´t care less about others (China).
The GREAT point about electrical cars is they allow clean but fixed point Energy: Hydro and Nuclear mainly, into a form light and portable enough to be carried on 4 wheels away from the grid.
Electric trains, tramways, trolley buses, subways, etc. allow for clean efficient transportation for way over 100 years now, but of course along power lines.
Thermal power stations still play a major part in ensuring the frequency stability of the electricity supply.
Solar and wind technologies are more difficult to control.
Well...Solar and wind are intermittent, no control at all.
Wind electricity is only 25% available over all of lands in Europe. The 75% of the time with near no wind, power MUST come from sources one can control. Without nuclear, that is gas mostly, from Russia. The situation is so bad that we will boost electricity generation from coal.
