Music is art, audio is engineering.Awesome, that's it. It's a data thing. I have an account with both of those suppliers, and that's exactly what I've been doing - it just seemed too "technical"..
Seriously, the particular part is only part of the story (no pun). A good designer 'kneads' the collection of parts to do what he wants. Parts selection is necessarily a compromise between what's available, its characteristics, the price etc.
People like Nelson are seemingly able to 'knead' any part into submission 😉
Jan
On a fun note....
One of the contributors to this thread was nice enough to sell me a pair of Model 6A boards that arrived today.
These will replace the Model 6 boards that are mounted on heatsinks with double the square area of the stock heatsinks
after I replace the bias pots with 3296s and the Nichicon Muse with Silmic IIs.
The heat sinks attach to the new grown-up chassis.
The 70,000 uf of capacitance on each side requires a 6 ohm, 100 watt input resistor to keep the lights on, and I'm quite certain that they don't make the slightest difference in sound, but this exact set of four was available at a crazy price, and are just so much fun to look at. 🤓 The aluminum bridge is a re-purposed drywall compound pallet. 🤔
The faceplate was scrubbed and silkscreened to match my other Mark Levinson gear, which was scrubbed and re-filled 15 years ago just because I like silver instead of black.
Fun!
...and now, back to our regularly scheduled programming.....
Fun!
Jan
"Usually the parts tell me how they want to be used. Much easier that way."
Sorry... do you guys still get excited when new parts come in...?
Very helpful! I don't have to take it so seriously, trying some different parts and seeing how they work/sound seems logical (Captain).
I will order some MOSFETs and try them, and let you know how it goes. Thanks again.
TI just came out with a new opamp, max supply +/-42.5V, 10MHz, 40V/us, 6nV/RtHz.
That excites me because it opens up a lot of new circuits I couldn't do so far.
Jan
Jan
Whew... okay.
Nice to know I'm not the only one.
Although, I'm sure your projects are a lot more complex than my "projects".
I'm lusting after your equipment!Whew... okay.
Nice to know I'm not the only one.Although, I'm sure your projects are a lot more complex than my "projects".
Jan
Ha ha... just kiddin. The Model 37 CD transport needs a lot of attention after 25 years - the "grease" that they used throughout the open/close mechanism dries out and gets sticky. The whole transport needs to come out of the chassis and be completely disassembled and cleaned, then I used a light silicone grease on the rails and the mechanism. Works well now, but i think a lot of owners get very frustrated with them and sell them cheap.
Hi Naresh, glad you're still hanging out here! That is an excellent suggestion, and when I looked at what I used, guess what I found...?
I thought the Super Lube would be good in this application because it's a very light, clear grease, but it looks like it had other benefits as well. Teflon!
Yeah, I like to think I'm very fashionable, but the fact is that the older I get, the harder it is to see the black stuff without my glasses. 😥 🧐 😅The ML gear looks great in clear anodizing.
I think I have some of that. Probably in the bedstand (sorry couldn't resist).Hi Naresh, glad you're still hanging out here! That is an excellent suggestion, and when I looked at what I used, guess what I found...?
Jan
I have no idea what you are talking about. 😡😛
Constipation and sodomy jokes are not funny!
Jan
Always in trouble... But it's so much fun! 🤣 🤣
Riddle me this, Batman...
I have one Rogue IGBT on one side of my Model 6 which shows more than double the value of the other 7 (at low boost, 21.7, 21.3, 21.7, 20.7, 21.6, 21.6, 22, 56.5 (!). Since these things aren't available any more, and I don't have anything that will match it, is there any disadvantage to doubling up the emitter resistor from .47 ohm to 1 ohm to control that excess current flow and allow me to bias that entire side up?
Thanks!
Thanks!
- IGBT Conversions for Forte Audio Amps?
