Your most hated chip amp
The irs2092 takes a little while to get to grips with.
Took a couple of pcb reworks before I could get a reliable output.
I was using mosfets with high capacitance gates and the 2092 didnt like it.
I had to use gate drivers to drive them hard enough.
The 2092 was seeing mosfets turn on slowly and assumed an overload.
Not a bad chip once you get to know it.
Or just stick to application note layouts etc.
LA4425. Since the TDA2003 was discontinued, I thought this would be a nice replacement with fixed gain and low part count. It has the gain set too high and very noisy.
TDA7240. This was a bridged output chip in a TO-220 package (7 pins). It was prone to oscillation. I tried playing around with the layout and got it usable, but it didn't seem to like long speaker leads. It might have been tamed with an inductor on the output but I never pursued it.
Years ago, I discovered that you cannot use too much feedback on a LM377, and more recently I found the same problem upgrading the circuit around a commercial mini stereo, which had a similar part. But once I reduced the feedback to a stable system, it sounded great and ran cool. I think a lot of "bad sound" is actually instability due to over optimistic feedback levels. When the data sheet saz "minimum gain", you need to pay attention. A resistor between the + and - inputs is a simple solution.
"The amplifier is also internally compensated for gains of 10 or greater."
deep in the past, back in socialist era, we had to use this chip a lot, MBA810, dreadful sound
We knew it as a TBA810. That was definitely up there in the worst ever 🙂 Used a lot in TV's and one make and model had two identical plug in PCB's, one was audio output and one was frame output. The output coupling caps used to fail (high esr) on the frame stage giving frame cramp at the bottom of the screen so the quick fix a lot of techs used was just to quickly swap the boards over.
TDA3000's in a 7 pin TO220 package used to give us problems as well. An interesting chip but we had a lot fail.
When I got my hands on this version I wondered how to make a PCB for it.
