10kw of tube power can be yours for $25,000.00
I'm not selling anything and this ain't spam. I just came across this and thought it was pretty nuts thought some of you might want to see it. It can be yours for a mere $25,000.00 USD but you will need two so you might want to bring $50,000.00 and a Ryder truck with a lift gate. They are the size of a closet and will heat your house like a pot belly stove but think of all the bragging rights you will have. It's like a whole jigiwatt of pure tubalisious power. I have no idea what they would sound like but I'm pretty sure two of these could power the next Oz Fest.
https://www.surplussales.com/Microphones-Audio/MicroAudio-7.html
Here is the manual for the beasts.
You NEED a 10KW dummy-load to safely work it at 10KW output. Then you may get 20KW heat between amplifier and dummy load. That's ~~65BTH/h. Which around here is not a large house furnace. And any fool can push a pot-belly stove harder than that. Ask the fire dept.
For a little more resistor money and a LOT less amplifier money (and shipping!) you can get a 20KW dummy load. Look for "electric baseboard", although you can also find electric furnaces for the house.
68,242 BTU 2 - 3.5 Ton Mobile Home Electric Furnace with ECM Blower Motor $1500
20 kW worth of heat strips barely puts a dent in the heat load when it’s less than 20 degrees outside. Might get it to 55 in the living room, and we’d be freezing our ***** off. Propane furnace does just fine.
A couple water heater elements works as a dummy load. Water required. Keep adding ice.
May want insulation? 20KW is like 68,240 BTU/h. In my 1,400sf saltbox, my 42,000 BTU furnace will hold 65F inside for -5F outside, and 69F whenever it is above zero F. (And the 42k BTU rating is probably Input; but at >94% efficiency that makes small difference.)
This thing might have oil caps and only need to eject the selenium rectifiers.
I have a large Wurlitzer organ that had a large selenium rectifier for the low voltage stop controls.
The thing started smelling a little and I knew the rectifier had to go. Quickly replaced with a bridge of some sort.
