10kw of tube power can be yours for $25,000.00
About 15 years ago I saw a couple of these type units get parted out at a scrap yard in Connecticut. Copper containing stuff was $2 a Lb,, other stuff $1.50 a Lb. The oil caps went to toxic waste disposal. I didn't see anything useful/practical in the lot. You'd have to pay money to get rid of this type heavy stuff now.
Reactions: Midnightmayhem
I worked with a 30KW UDCO circlotron until we replaced the vibe table, including a IGBT class-D, about 50KW.
https://www.udco.com/products/replacement-power-amplifiers/
The circlotron used a two arrays of stud mount NPNs in water pipes. Note these amps have to handle ~1Hz.
Hydraulic tables have a very limited frequency range, so they are only used for shipping test and similar. Most shake tables are electrodynamic.
