Iam planning to use 6c45 as a input tube for a ss amp SE.
But I Wonder how Hard I should driver it.
Im thinking 20 to 30mA , or is it any benefit
In going to 40mA?
In going to 40mA?
Joined 2009
I'm not currently using one but have played around with one and a colleague has used it for many years. The thing that I would be looking at is more 'subjective sound' than about power dissipation vs life. There are people who have used these tubes and found them a little harsh. I've had more experience with it's brother, the 6E5P tetrode which when triode-wired is a similar beast. it seems that a number of users have found that the subjective sound is not optimal at all currents and you may want to keep some flexibility in your design in case there is a sweet spot for your implementation. And I don't think it's all about harsh = parasitic oscillations, it's more than that.
What is the load of 6c45 ?Iam planning to use 6c45 as a input tube for a ss amp SE.
If I see correctly, this amp requires only 11V peek input.
It's not high gm tubes territory, any tube capable to produce 22Vpp swing.
IMHO better choice 6-8x gain capable low output impedance tube.
https://www.diyaudio.com/community/threads/lufo-amp-39w-se-class-a-from-28v-rail.372679/
A noob question about induktor.
Lets say I have an induktor 30H/40mA.
Do I have to run 40mA trough it?
What happends if I use sayy 20mA trough it?
I see a lot of People writing that the 6c45 sounding hars.
So I m thinking of going with the 6e5p
Imstead..
Comments on that...
Imstead..
Comments on that...
I see that on the datasheet it says that 6E5P has a service life guarantiee of only 500h,is that correct?
Maybe i should use the 6E6P instead wich has a lifetime of 10000h...
Any one been using the 6e5p for a "long" time and can comment on the lite time?
500h seems rather shorts...
In found this link ssying that at 200v 6e5p has an amplifying at 50.. is thid True,?
http://www.jacmusic.com › T...PDF
6E6P-1 Triode curves made with SOFIA curve tracer. - JACMUSIC
Sorry cant get the link right on my Phone..
Mu 30-35 in triode mode.In found this link ssying that at 200v 6e5p has an amplifying at 50.. is thid True,?
I thought so,I am at the moment leaning towards using 6E5P.
As people are are saying they are very transparant and have used them for several years.
As a gain stage 150V anode 20mA works quite well in my experience. I’d use a cascode depleteion mode mosfet CCS as a load. I have used a 70H choke and like the CCS load better. Diodes for cathode bias, between 1.5 to 2V. I’ve also run them at 175V 40mA in a PO class A spud and they sound wonderful there too.
- Tubes / Valves
- How hard do you drive your 6c45?
