Use cable ties to mount the components so they are not glued down with hot melt. Easily interchangeable.Haven't proceeded as yet as I'm trying to get my head arrange assembling the crossovers in such a manner that I'm able to easily alter them without damage or distress if I decide to go to version 2.
Thanks Salas.Use cable ties to mount the components so they are not glued down with hot melt. Easily interchangeable.
Cable ties are definitely the way to go.
For me it's more the component wiring connections.
Solderless wiring until establishing which way to go.
Ensuring good electrical connection without compromising the actual wires.
Crocodile clips/leads can be useful for temporary connections, and for testing. They are designed to bite past dirt and corrosion on the surface when used sensibly, to make a usable connection.
