Do you mean that I have to put a voltage on the secondary side e.g. and see what is measured on the primary side? The ac voltage there should meet then the anode voltage when the amp is in max. use?You could run a small ac voltage to the output (a few volts) winding and look for reasonable and matching high voltage (remember it will be stepping up a good bit!) on each side of the primary from the center tap. I think that's a more reasonable approach. That or just try it out and measure in circuit.
I understand the concept, but it would fail to notice a fault on one side. You could have a shorted side and still get a valid output. And unless you very carefully compared it to a known good transformer, you really know nothing. Doing it in reverse you can compare each half of the primary. And let's face it, if something failed, it's most likely the primary winding in some way. It makes much more sense to do it in reverse.The mains would be connected from anode to anode , you don't use the central tap ... tests can be done in many ways , this is simple and you don't need anything
Also, hooking mains directly to a possibly damaged transformer sounds like a bad idea to me too.
Yes, remember it's stepping up... so 3v AC might become 60 or 120V etc.. depending on the exact ratio of the unit. The thing I like is you can compare from the center tap each half of the transformer and make sure the voltage on each side matches. It's possible for one side to short, think 40 turns is now 20, and in that case would see very different AC values on each half. They don't have to be perfect (and likely won't be) but if they are significantly off, it's likely bad. Or you could even have 1 side not working at all if it opened.Do you mean that I have to put a voltage on the secondary side e.g. and see what is measured on the primary side? The ac voltage there should meet then the anode voltage when the amp is in max. use?
Actually that's not quite right, due to mutual inductance a short in one side of the primary will affect the results across the entire primary. An open likewise would do the same (that's somewhat more obvious). Testing across the primary is a time honored way to determine whether there are shorts in either primary or secondary (again mutual inductance) and to measure primary current at a known frequency and voltage and determine the inductance under conditions that more closely approach normal operating conditions. Use an isolation transformer for safety. Some means of limiting current in the primary is recommended, and I strongly recommend checking the transformer for winding to core shorts first.I understand the concept, but it would fail to notice a fault on one side. You could have a shorted side and still get a valid output. And unless you very carefully compared it to a known good transformer, you really know nothing. <snip>
How you can do a power transformer with shorted turns to run "valid " ? This is the same , doesn't matter if it is an output transformer . In coupled windings any shorted turn would make the whole transformer to be bad . And both halves of a push-pull transformer are in phase , just to be clear , from plate to plate it is not canceling out . Remenber that a 220V power transformer with 110V tap can be used as a push-pull transformer very well .I understand the concept, but it would fail to notice a fault on one side. You could have a shorted side and still get a valid output. And unless you very carefully compared it to a known good transformer, you really know nothing. Doing it in reverse you can compare each half of the primary. And let's face it, if something failed, it's most likely the primary winding in some way. It makes much more sense to do it in reverse.
I did some tests (very carefully) With the result 12V on the 4 ohm output, gave me 2 x 163V (a-mid) (315V a-a) on the primary coil. Both transformers gave the same result. I think there is nothing wrong with my output transformers. I will now repear the rest of the amp and test the tubes if I can still use them .
This basically is what I recommended in #16, and it allows to disclose shorts in one primary half as well by comparing the voltage readings from CT to each plate terminal.Use an isolation transformer for safety. Some means of limiting current in the primary is recommended, and I strongly recommend...
In a defunct power transformer of an old Dynacord Eminent II amplifier I found exactly which winding is partially shorted by this way. It's one of both plate supply secondaries.
Best regards!
Congrats my friend. Good luck on the repair!I did some tests (very carefully) With the result 12V on the 4 ohm output, gave me 2 x 163V (a-mid) (315V a-a) on the primary coil. Both transformers gave the same result. I think there is nothing wrong with my output transformers. I will now repear the rest of the amp and test the tubes if I can still use them .
Result. Well done!I did some tests (very carefully) With the result 12V on the 4 ohm output, gave me 2 x 163V (a-mid) (315V a-a) on the primary coil. Both transformers gave the same result. I think there is nothing wrong with my output transformers. I will now repear the rest of the amp and test the tubes if I can still use them .
This is good news. I would probably replace all of those output tubes. The Russian 6P14P-EV is rugged enough for operation at these elevated voltages. Try to get matched quads if possible. Best sources are probably eBay sellers in former Soviet bloc countries.
Thank for this. I will try to get the 6P14P-EV.This is good news. I would probably replace all of those output tubes. The Russian 6P14P-EV is rugged enough for operation at these elevated voltages. Try to get matched quads if possible. Best sources are probably sellers in former Soviet bloc countries.
Anode voltage 440V ??? This amp Getling throws its barrels as a weapon ... The EL 84 can dissipate 12W and the Russian 14W. Guitar amps are used to be stretched like this, if someone did something like that with an animal, I would be imprisoned for life ... 🙂
It can be done close to class B , the power dissipation / current is high only when you are listening at very high volume .
Hi, I got a stereo tube amplifier for repair. 2x(4xEL84). Some sparks of tension has taken place, burned places on the circuitboard. I have measured the output transformer for self-induction and now it appears that they show about 30% deviation. From anode to anode, one is 6.8H the other is 4.2H. Is this normal ? or is one transformer gone ?
yes, if the dc resistances are not the same, but even them there will be difference...
- Tubes / Valves
- PP output transformer
