Acoustic Horn Design – The Easy Way (Ath4)
This is perhaps the highest reasonably controlled DI I have seen in the set:
Was about to ask how narrow you can make it 🙂 It looks like the new formula is more versatile for sure.
Interestingly this one happens to have lot nicer top end, and could have smaller mouth to meet 15" driver than the previous ones.
Frequencies above ~10 kHz are affected especially by the throat details and that is pretty independent of the rest of the waveguide (different 'k' values). So in these examples the behaviour above 10 kHz may not be directly related to anything below that and could be different with a different value of 'k'.
It seems there's nothing one can do to make the DI lower than about 15 dB at 20 kHz (for a simple open 1" throat, that is). So if it's already that high below that, it makes a "nicer" top end...
This is also possible, I'm only not sure it's the best way:
Above 3 kHz the DI (and the -6dB beamwidth) is as flat as possible but the frequency responses in the listening window are actually not (and I guess that's how it must be). I believe that better would be to let the DI rise gently with the listening window flat (which can be done).
More something like this:
It's only around 10 - 12". I've done this before:
https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6760729
https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6752296
https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6744458
This way it's printable without any supports and one can make quite big waveguide even on a small printer. It's glued and it's a lot of work, I'm not sure I would recommend it to everyone. For me it's certainly a way of testing these things.
I put the Tritonia in a minimal baffle enclosure and simulated the freespace response with a dome tweeter as the original worked well with a spherical source.
I like it, within the listening window the responses are extremely similar to each other and fall off smoothly outside.
Reactions: neutrino_th and Zvu
The final parametric equation, in case someone already wanted to explore it.
I write a paper on that but it will take some time...
Code:
R = 180         # outer radius of the waveguide
a = 38.2        # nominal coverage angle
r0 = 12.7       # throat radius
a0 = 0          # throat angle
k = 0.88        # throat expansion factor
m = 0.85        # apex relative position
r = 0.31        # apex radius factor
b = 0.37        # bending factor
q = 3.00        # throat weighting factor
k1 = (k*r0)^2
k2 = 2*k*r0*tan(a0)
k3 = tan(a)^2
L = (sqrt(k2*k2 - 4*k3*(k1 - (R+r0*(k-1))^2)) - k2) / (2*k3)
x0 = L*sqrt(r*r + m*m)
b0 = (x0 - L*sqrt(r*r + (1-m)^2)) / (L*L)
y2(l) = sqrt(k1 + k2*l + k3*l*l) - r0*(k-1)
y0 = L + y2(L)
y1(l) = y0 - sqrt(L*L + k3*(l-L)^2)
w(t) = t^q
# t=<0,1>
x(t) = x0 - sqrt((r*L)^2 + L*L*(t-m)^2) - b*b0*(t*L)^2
y(t) = w(t)*y1(t*L) + (1-w(t))*y2(t*L)
Would it be possible to have ATH output a set of kit stl files ready for 3D printing? Would be helpfull for guys like me that lack all the skills...
I wish I could be more helpfull. I try though. I ported (part of) MMM to python in order to try to utilize the GPU for the calculations. That succeeded after quite some hard work, but it is slower than the CPU version. Too bad, I dreamt of playing with some sliders for the OSSE parameters and getting some 'instant' feedback.
I can only recommend Autodesk Fusion 360 which I've learned myself just for this purpose (the few bits needed). It's really intuitive and easy to work with - to produce a STL model of an axisymemtric device takes a couple of minutes (see https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6499437).
