Get regulated 6.3 VDC from 6.3VAC
Update: AC voltage = 6.85V (it will supply the heater of the output tubes, maybe I will reduce it with a series resistor)
Average DC voltage on the puffer capacitors: around 8V (changing +/- 0.1V), ripple: 0.75Vpp
Stabilized voltage: 6.36V, no noise 🙂
Calculated dissipation: 2W (1.7V drop x 1.2A load current)
