DAC AD1862: Almost THT, I2S input, NOS, R-2R
Thanks Miro.
But it doesn´t play music 🙁
From what I remember is that JLSound has an SPDIF out function as well, what I will be doing in your position is as follows:
1) get the SPDIF function working, separate the JLSound from the DAC and play some music via usb, get the SPDIF out and put it to any other amp, if there is sound then it means the JLSound I2S is working.
2)In my experience crackling noise through DAC is only produced when the digital inputs are incomplete mean one of the signals is missing LRCK, BCK or Data.
I think I experienced the same in one out of the three DACs that I made earlier, turned out there were two problems in one case the shift register got over heated during soldering and was was gone, second time there was problem at the connector.
One has to check output at each shift register.
@miro1360
Power supply is connected according to manual page 3
@rehanabid
I don´t use the shift register as Miro recommended(see pic). DATA is splitted in DL and DR on JL I2S board and connected to DAC board.
I don´t have an amp with SPDIF in...
Here are also Gerbers and schematics for the D1 thanks to the mighty ZM.
The D1 featured a PCM63, spec sheet says output for that chip is +/- 2ma - the AD1862 outputs +/- 1ma. I am not qualified to comment on what result that would have in the circuit but hopefully that is in some way helpful to you
It means that the I/V circuit will produce half the output voltage amplitude/gain via the AD1862, but also decreased distortion as a result of that. The decreased gain can be compensated for if required, but doing so would then have the consequence of altering both MOSFET's bias conditions. Likely resulting in increased distortion.
@miro: As on Vunce´s I2S board there is no U10 installed. It looks like a layout design revision.
The jlsounds doc describes B1 to B5 short bridges. On my board it´s B1 to B6 as you can see from first picture in post #3245.
@woodturner-fran: Yellow trace is lrck, blue is bck (first screen shot)
Yellow trace = DL, Blue trace = DR (third screen shot)
The square waves are not very clean? 🤔 LRCK should be 64xBCK slower 🙁
Try different USB cable (shorter) because it must deliver 400mA
Hi Jim,
These are the Molex KK series headers, crimps and connectors that all mate together plus the Engineer PA 20 crimper pliers for perfect crimp jobs. 👍
https://www.mouser.com/ProductDetail/Molex/22-01-3027?qs=cRUT3GdJqnwywyFd19%2BSsA==
https://www.mouser.com/ProductDetail/Molex/22-23-2021?qs=ILqg114nvd4YKlRlbo3yMg==
[URL
unfurl="true"]https://www.mouser.com/ProductDetail/Molex/22-01-3027?qs=cRUT3GdJqnwywyFd19%252BSsA%3D%3D[/URL]
https://www.mouser.com/ProductDetail/Molex/08-51-0108-Loose-Piece?qs=8%2Bu/V6/T1OrE67rmlr2KVw==Engineer Inc PA-20 Precise Universal Wire Terminal Crimping Tool https://www.amazon.com/dp/B002AVVO7...abc_1YKSJZ62RA73ZMQYZFXQ?_encoding=UTF8&psc=1
EDIT: scratch the following comment, the jumpers for AD1862 12v are arranged in such a way that I can use the molex connectors for those and the regular 12v for my analog stage. Perfect!
Vunce I just ordered a bunch of these parts and they fit great, thanks for the pointer.
Im looking for a 1 x 1 header connector and I cannot for the life of me find one -- do you know where I would find a 1 pin connector like these ones you linked?
(this will be used to power my IV op amps separately from the DAC 12v on miro's board, so they need to go through the jumpers)
@jimk04 for AD1862: R4, R5, R6, R7 = 3k3 ... the same for left channel 😎
With respect, the values used in the original D1 were calculated for PCM63 which outputs 2ma of current. The AD1862 only outputs 1ma of current. The values have to be doubled. The Drain resistor to +ve supply should be close to 3K and the Source resistor to the -ve supply should be close to 6K6. You may need to reduce the values downwards if the gain is too high.
