I doubt that the force of a tweeter voice coil could result in such a huge damage (supposedly leaving the magnet gap).Possibly over excursion of the dome?
also, i suppose the susupension would limit the max excursion long before the dome hits the grille...
That's a good critique of my reply.I doubt that the force of a tweeter voice coil could result in such a huge damage (supposedly leaving the magnet gap).
I notice you haven't contributed anything to the OP at all.
Do you have an opinion on how the damage was caused?
Or you just like to put down others responses?
If it means anything my Jordan JX92s fullrange drivers developed few kinks, on both drivers. I attributed to children damaging them until I noticed fresh wrinkle with no kids around. The cone damaged due to listening too loud! Some breakup or bottoming of suspension or something makes so much force a wrinkle appears, at least that is the most reasonable explanation I could come up with at the time. Perhaps there is some tension on the material which fails with a enough resonance and deformation happens. Perhaps this can happen to a dome as well.
Did you have a party? If not, check the amplifier output with scope, just in case, before rolling in another pair Music doesn't usually contain mucho highs but distortion does! Or the amplifier could have some oscillation why not.
Keep feeding energy to resonance and things break
sorry about that, mondogenerator, i did not mean to be rude. I should stop posting without enough time to think ...That's a good critique of my reply.
superlian, one possible other cause might be a sudden air pressure increase, such as opening a air tight enclosure after a long air transport?
edit: i should add that i once damaged my seas alu dome tweeters when measuring the distance to the microphone with a pointed ruler. i got similar measurement results to yours. I was able to "repair" the domes by carefully pressing the domes into shape after removing the diaphragm construction from the magnet. the strong resonance of the indentation disappeared, but I suspect the 15 kHz resonance will remain (see picture).
The owner og the tweeters tells me that he was trying it close to the dustcap to TAD1201 (>10 kg magnet) as a coax. He used som steel wire to keep it in place i think. Could the magnet force from TAD1201 pull the voicecoil and dome like a spring and then release it so it collided with the grill?
https://audio-database.com/PIONEER-EXCLUSIVE/unit/tm-1201-e.html
The shape of creases seem to follow the grill pattern
If that is true might a crossover change be good advice ?
the voice coil and dome are non magnetic (if no current flows), but maybe the grilles themselves are magnetic and could have been deformed to crush the domes?Could the magnet force from TAD1201 pull the voicecoil and dome like a spring and then release it so it collided with the grill?
No, the grills has not been deformed....but maybe the grilles themselves are magnetic and could have been deformed to crush the domes?
Maybe the damage is because I didn't use protecting caps?
I am the owner of the tweeters.
I use T34B now, and YES, I use protecting caps on them.
Bergfinn told me that T34b in comparison sounds signifcant better.
I think t34a should sound almost as good as the beryllium version. The beryllium version should only have a small touch of «silk oil» in adittion.
I have earlier tested Seas DXT vs T34b and DXT didnt sound bad in comparison.
My conclusion is that Bergfinn heard the distortion from the dents in T34a and that they therefore sounded like 15 USD metal dome tweeters.
- Strange thing happened with Bliesma T34A
