Strange thing happened with Bliesma T34A
Does someone have a idea of what happened here?
It could be a children but the mesh is very fine/narrow and the problem is 100% equal on both.
I doubt that the force of a tweeter voice coil could result in such a huge damage (supposedly leaving the magnet gap).
also, i suppose the susupension would limit the max excursion long before the dome hits the grille...
That's a good critique of my reply.
I notice you haven't contributed anything to the OP at all.
Do you have an opinion on how the damage was caused?
Or you just like to put down others responses?
If it means anything my Jordan JX92s fullrange drivers developed few kinks, on both drivers. I attributed to children damaging them until I noticed fresh wrinkle with no kids around. The cone damaged due to listening too loud! Some breakup or bottoming of suspension or something makes so much force a wrinkle appears, at least that is the most reasonable explanation I could come up with at the time. Perhaps there is some tension on the material which fails with a enough resonance and deformation happens. Perhaps this can happen to a dome as well.
Did you have a party? If not, check the amplifier output with scope, just in case, before rolling in another pair :) Music doesn't usually contain mucho highs but distortion does! Or the amplifier could have some oscillation why not.
Keep feeding energy to resonance and things break
stv
Joined 2005
sorry about that, mondogenerator, i did not mean to be rude. I should stop posting without enough time to think ...
superlian, one possible other cause might be a sudden air pressure increase, such as opening a air tight enclosure after a long air transport?
edit: i should add that i once damaged my seas alu dome tweeters when measuring the distance to the microphone with a pointed ruler. i got similar measurement results to yours. I was able to "repair" the domes by carefully pressing the domes into shape after removing the diaphragm construction from the magnet. the strong resonance of the indentation disappeared, but I suspect the 15 kHz resonance will remain (see picture).
Bergfinn told me that T34b in comparison sounds signifcant better.
I think t34a should sound almost as good as the beryllium version. The beryllium version should only have a small touch of «silk oil» in adittion.
I have earlier tested Seas DXT vs T34b and DXT didnt sound bad in comparison.
My conclusion is that Bergfinn heard the distortion from the dents in T34a and that they therefore sounded like 15 USD metal dome tweeters.
