But not very different to the Vas of the Definimax 4015LF?nice B&C... only Vas in on low side
As test I'll try with Delta15 from my Pi speakers and after I'll decideLooking good Peppennino. Have you settled on a bass driver yet?
yep but not the same qts..btw as Pa tell as will work fine ,is speakers have slot load + floor boostBut not very different to the Vas of the Definimax 4015LF?
try this newlink , ok you need joint to this FB OB group...Clicking the link says I don't have permission. Are you sure you made it shareable?
So, I have bitten the bullet; this morning I placed an order for a pair of these;
https://faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=151060150
I'm not into motorbikes so had to look up that Ducati model - very racya DucatiCorse woofer 😊
This is my own 'Italian bike'
viner is closed on 2013 ...now is in sheffield ,there isnt icetech disk brake in 2013 and pink is not talian stile 😉I'm not into motorbikes so had to look up that Ducati model - very racy
btw planet X is good and frame can be rigth as DT and 105 ...
Yep, the Viner brand is owned by Planet X, based in Sheffield here in the UK, though the frame was almost certainly made in China. The frame colour scheme and decals are to celebrate the 100th edition of the Giro d'Italia in 2017.
The pink bike is my 'everyday' summer/training ride and is stored during the winter months. It's a good, comfortable and fast ride for clocking up the kilometres. Shimano 105 groupset and Fizik cockpit.
With the short days and seemingly constant rain here in the UK at the moment, and because I'm nursing a shoulder injury following a bad fall, currently my riding is indoors on 'Zwift'. I'm by no means a top rider (I'm 64yrs old but in the upper quartile for my age group) but I find cycling is great for my physical and mental health and I plan to keep going for as long as I can. In May I plan to 'Ride London' - a 160Km event around the (closed) streets of London.
Perhaps you should tell the organisers of the Giro d'Itlia to change the maglia rosa...
...pink is not talian stile 😉
Anyway, back to the SLOB...
I have a friend who works with CAD and he's producing the files to get the SLOB structure CNC machined from birch ply. The baffle panels will be removable and to start with I'll use a chaep plywood so I have the option of trying different full-range speaker units but eventually I will get some baffles made from clear acrylic.
I have the bass and some full-range units sorted, a 100Watt Class D amp for the bass and a DSP unit to get the initial crossover/equalisation parameters (will later upgrade to the LX-Mini crossover). Today I'll be working on the amplification for the full-ranger.
Progress is slow (like all my projects) but my SLOBs are beginning to come together.
you can use a 28 size ,with 320 cotton tpi like Vittoria ,for smooting ride ,hope fast recoveryYep, the Viner brand is owned by Planet X, based in Sheffield here in the UK, though the frame was almost certainly made in China. The frame colour scheme and decals are to celebrate the 100th edition of the Giro d'Italia in 2017.
maglia isnt a frame 😉
I'm running 25mm tubeless, Schwalbe Durano - excellent ride and good puncture resistance.you can use a 28 size ,with 320 cotton tpi like Vittoria ,for smooting ride ,hope fast recovery
On my winter bike I have 32mm tubed, Schwalbe Marathon Plus.
- Papa’s slot loaded open baffle version #2
