A/C voltage on B+
I'm trying do find the source of 60hz hum when I noticed the ac on my b+.
280v it would be higher but I am using a transformer that steps my voltage down to 105v. It has a 110v power supply in the amp. I'm waiting on the bucking transformer to deal with that.
This 120Hz ripple may be about normal on the input capacitor, but it should be gone after the following LC filter.
If the ripple on the 47uF is only 60Hz, one of the rectifiers could be bad or have a poor connection. In this case,
the B+ would usually be much lower than normal.
I think the B+ is fine. The amp sounds very good other than the hum. if it was 120hz I'd suspect that but it's definitely 60hz
If the hum is really 60Hz, it could be magnetic coupling from the power transformer.
Also the 120VAC power switch and wiring is close to one of the output transformers.
Is the hum stronger in one channel than the other?
Oh I see what your saying. That's the choke under the power switch, the outputs are in the back on the other side of the can cap.
Thanks.
Doesn´t look like much, it´s only 5% ripple, and that at a high consumption rate (Class A amp), besides "Single ended amps Hum" because there is not self canceling as in a PP amp.
So not "bad"|(aas in nothing broken) but of course you may try to lower that even further.
