KiCad EDA V6 was released on the 25th.
Available for Windows, Mac and several Linux distributions
https://www.kicad.org/
Only just recently installed V6. Haven't had too much time to play around with it (still on V5.xx at work), but thus far I'm impressed.
i've been playing with it today.
i agree with you; it is impressive and VERY nice.
It has matured really nicely. However I'm disappointed that they didn't make it easier to exclude soldermask from tracks without having to draw over them. That's one of the things that was really annoying in v5 and I was hoping they'd fix it.
However I'm disappointed that they didn't make it easier to exclude soldermask from tracks...
While an old request, it only has a single up-vote: https://gitlab.com/kicad/code/kicad/-/issues/2125. 🤷♂️
I don't know if this is exactly what you mean, but in v5 I often used the Solder Mask Expander in the RF-Tools plugin to keep mask off traces.It has matured really nicely. However I'm disappointed that they didn't make it easier to exclude soldermask from tracks without having to draw over them. That's one of the things that was really annoying in v5 and I was hoping they'd fix it.
V6 contains so many things that were at the top of my wishlist. Both eeschema and pcbnew have so many improvements, I'm still having to remind myself to use them. Very, very, very glad I didn't decide to buy Easy-PC when I started doing this stuff.
There are feature(s) that got attention without much up-votes, this one has only 2 and is scheduled for v7.0, which means it will be added. Another one is Teardrop which only has 14 up-votes and is being implemented in v 7.0 as well so as a conclusion I can't see the actual weight of up-votes on the developers decisions, hence a couple of up-votes doesn't sound too bad for this old request and many other old/new requests.
In the meantime, there is a plugin for that "Soldermask expander for tracks v2.3", I believe this plugin is part of the RF-tools plugin:
Having a milestone doesn't mean it's scheduled for a particular release. It just means that someone is going to look into it for that release.
Teardrops had many, many up-votes. Sadly our migration from Launchpad to Github left the old upvotes in a different field, with a different scaling (see the "weight" field and divide by 6).
But in any case a feature gets built if (1) a developer wants to work on it or (2) it has a lot of up-votes and a developer is willing to work on it. (1) doesn't require any up-votes at all, and (2) still requires that someone is at least somewhat interested in it. It is, after all, a volunteer project.
(Actually there's also (3): if someone is willing to pay someone else (such as KiCad Services Corp) to build it.)
The thing that I think would be most useful at this point is a better way to handle repeat features. For example, say you have ten voltage input channels on a device, that are all copies of each other, feeding into a single ADC section. Okay, you can handle some of that on the schematic side with hierarchical sheets, but on the PCB side, it's a real pain to deal with.
This is one of our highest-requested features:The thing that I think would be most useful at this point is a better way to handle repeat features.
https://gitlab.com/kicad/code/kicad/-/issues/1998
Did you try the replicate plug-in? It's the coolest function ever and worked really well for me once you get the hang.The thing that I think would be most useful at this point is a better way to handle repeat features. For example, say you have ten voltage input channels on a device, that are all copies of each other, feeding into a single ADC section. Okay, you can handle some of that on the schematic side with hierarchical sheets, but on the PCB side, it's a real pain to deal with.
It copies pcb-layout from one hierarchical sheet onto all the others. Just Google it and you will find a tutorial.
Teardrops is a very frequent request as it is needed for flex pcbs
I'm using the teardrop plugin mentioned this reddit thread. It's not perfect, but it works well enough.
V6.0.2 has been released with many more bug fixes
https://www.kicad.org/blog/2022/02/KiCad-6.0.2-Release/
- Design & Build
- Software Tools
- KiCad EDA V6.0 Released
