Exploring Purifi Woofer Speaker Builds
Hi, i am a big fan of aerogel, my first speakers that i have built around 15 years ago were using only Audax aerogel midwoofers and midranges, these were very good at the time. But i didn´t know that you can buy it ready made as an absorption material, can you share the source please? Thanks!
Yes they were nice drivers. I remember back in the 90’s going into a hifi shop and listening to a Duntech speaker that had dual 8” Audex Aerogel drivers in a sealed cabinet. That’s when I decided that sealed was the only way for me. Found a picture. Duntech Viceroy. They also make good use of felt waveguides, and time alignment.
Regarding the aerogel, I need to keep some trade secrets. But you got a hint anyways. 🙂
Melamine foam pads are 100 for $7 from China. Much cheaper and more durable than aerogel. They have quite a small tortuous pore that serves to dissipate acoustic wave pressure well. I don’t think nano pores of aerogel are needed nor most effective for dissipating pressure waves in the acoustic range.
Here is an example of how I use hot melt glue to install the foam pads to the inside of a speaker cabinet one at a time. They are 6cm x 10cm x 1cm thick pads.
Electron microscope image of melamine foam structure:
The foam can be used for diffraction control as well in the baffle around tweeters. I have used it around ribbon tweeter apertures.
Reactions: Zeadlloyd
I don’t use the aerogel for inside the cabinet. Only for diffraction, and directivity control on the baffle. Although it works great in the cabinet, it’s pretty expensive for that application. 96% of sound that hits it is absorbed from 600hz up. And can be 3D printed.
I was under the impression this was do it yourself audio: projects by and for diy.
Sorry to say, but so far, apart from very basic 4 vs 7 liter enclosure sims, we seen little more than a lot of bragging.
Some people might be interested in things that will make their speaker build sound better. Folks who are fine with mediocrity can ignore.
Show us what you have done with this driver, and add some real value to this thread.
And 1000x more expensive 😛
It’s actually cheaper because you can get away with less than half the thickness. But those tests don’t accurately reflect the real world advantage for baffle treatment usage. They’re based on putting a puck of it in a tube at different thicknesses. When you’re trying to absorb the off axis sound from a driver, you’re not trying to penetrate though the entire thickness of the material. So you want the material that will absorb the best, with the least thickness.
You don’t really know that, do you?
I’m not the one with the grandiose claims though.
Don’t know what? I just shared actual data. If you have data that’s more solid, please share. All of the absorption testing is conducted to demonstrate the ability for the material to absorb sound when used to soundproof walls, or noisy enclosures with loud motors or pumps in them. Not for the use in absorbing the off axis frequencies on a speaker baffle. So the material that can absorb the best with the thinnest penetration is the winner for this application. The idea is you want the sound to not reflect off the surface.
Besides I don't want to go over 10mm of thickness with my baffle treatment. Some people can use a foot of Basotech on their baffles if they want. But that wouldn’t meet my design goals.
Aerogel is a generic term applied to a myriad of materials.
A random graph off the internet is not proof of anything.
You made an extraordinary somewhat scienterrific statement and I’m looking for extraordinary proof like you would be exposed to in any peer review.
Stop with the deflecting, you alone carry the burden of proof.
