Joined 2009
Over the years I’ve found myself trying to filter the Multiway thread into horn speakers and non horn speakers. I don’t know the history of these forums but multiway vs full range has never seemed like the best way to categorize projects of interest for me. I tend to think more in terms of horns, towers and OB. Anybody else feel there’s a better option than what we have now?
In principle, I agree. It would very nice. In practice it might be very difficult for the Admin's to go back and segregate millions of old threads into horn and non-horn. But the admin's would have to tell us how difficult that would be.
What is the dividing line between the two? Obviously a full range Synergy MEH is a horn speaker. A Klipshorn is a horn speaker... I would assume that a JBL M2 is a horn speaker, even though the woofer is a direct radiator. What a about a 3-way tower with a pair of 10" woofers, a 6" mid, and a horn loaded tweeter? is that a horn?
j.
j.
Define a horn loudspeaker. Most so called are only using a horn tweeter. Or horn bass. The number of true horn systems are so scarce it is hardly worthwhile.
There is a forum feature coming tha will let you essentially create your own virtuak forums.
dave
dave
Given how much people like to argue, that's probably going to be the dominant trend in a horn forum, where the definition is left up to the individual.
jeff
jeff
Claimed response. 20-20. XO at 800 Hz. 20-800 Hz is a little over 5 ocatves. So less than half the spectrum is covered by a horn. And given horns typically max out on bandwidth at about 4 octaves, JBL is pushing the limits of what a horn can do,
dave
I use to, but over time have become ambivalent since a BLH, whether some form of TL or compression horn flare*, are in the scheme of things normally just big vent reflexes [BVR] since they're too small/short to load all the way down to its design cutoff [Fc]; so if splitting them out it seems reasonable [to me anyway] to divide them into compression horns and lump together all the many various [and of late, seemingly growing exponentially] TL/horn band-pass alignments now available to us and if really 'picky', break these down into specific sub-categories like is done on the High Order Quarterwave Society FB site: https://www.facebook.com/groups/bassaz/?multi_permalinks=5238758969472521
edit: *FYI/FWIW, my definition of compression loaded any type pipe/horn alignment: [sealed back driver or reactance annulled BLH = infinite baffle sealed]
it could get "strict" with nothing but FLH covering down to midbass and lower.
No reflex, Paraflex, TH, BP, Karlson, Cornwall, Heresy, Econowave
no BLH as those mostly enjoy FR application (and scoop limited mostly PA work )
with less restrictions, BLH may be included???
The bigger question is why are commercial products from Klipsch, JBL and other manufactures even being discussed here? I thought that this was supposed to be a DIY forum.
To me; while all speaker alignments are some form of band-pass [BP], a tapped 'anything' is some form of BP6 and higher.
Strictly a 'frame of reference' to me unless referring to DIYing a clone or variant.The bigger question
overall a separate "horn forum" should be a good thing as the multiway forum can load up with various topics too fast to keep track.
Klipsch has a nice technical-modification forum but understandibly that's relegated mostly to PWK's work.
How about a gallery thread, similar to the OB gallery, you could link pics to writeups/threads.
I agree a new forum would get messy. For me, it's guided waves vs. direct radiation. But we combine them all the time.
Lol ...trying to assert a clear distinction between what's DIY and what's not DIY, caused enough troubleThe bigger question is why are commercial products from Klipsch, JBL and other manufactures even being discussed here? I thought that this was supposed to be a DIY forum.
Besides, we need to discuss commercial stuff. Don't forget the old adage "Use your eyes, plagiarize" 🙂
Oh, and to all: hey, before we spin off a "Horn forum".....
will someone tell me exactly when a horn is a horn, and when it's not cause it's a waveguide ?
Just playing around guys 😉
If we had to come up with a non-ambiguous dividing line, it could be the use of a compression driver. If the system uses a compression driver, it is a horn speaker. Otherwise, not. It is not a great definition, but at least there is no ambiguity.
Actually, I would hate to burden our already busy admin's and moderators with this... too much pain, too little gain... j.
Few of us diy every part of our systems. Those who don’t diy loudspeakers, will buy some.The bigger question is why are commercial products from Klipsch, JBL and other manufactures even being discussed here? I thought that this was supposed to be a DIY forum.
Certainly many of those mentioned can benefit from some diy/mods. The Klipsch in particualr if you are using high Rout amplifiers.
Do note that this kind of request has been discussed a lot in the backroom and is VERY unlikely to happen. As suggested earlier there is a feature coming that will allow anyone to create their own personal virtual forums. You can create your own horn forum, to your own definition of what a horn system is.
dave
To me the natural dividing line would be whether the user designs/builds the horn himself - as opposed to buying a piece of plastic, fiberglass, or metal and bolting on a compression driver. That would include all horn woofage and custom made mid/hi horns because the design focuses on the horn itself.
I agree.If the system uses a compression driver, it is a horn speaker.
- I’d prefer a separate forum for Horn speakers
