Dave, thanks, and also I do like glitch art. But I wasn’t talking about mine, I was joining my predecessor in his opinion that the avatar icons are distracting and plain nick would be much more soothing to the eye. It requires work to move your eye around senseless graphic elements. Except for those who actually upload a custom image, which are few.![]()
Allen suggestted that the reason that your icon is not transparent as it needed to be resized from the size i attached. Try this one. It is 48x48 pixels, same size as avatar used in the left hand column.
dave
Hi the biggest problem I have is when I klik an old topic it start one page one and I have to klick jump to new button.
Why is the new button gone or automate it.
Ore do I miss something.
Rob
Rob
Signature length goes up a bit with donated amount by the way.Two more issues:
1. I miss the donors area.
2. Only a single line signature is allowed.
Nope, I think I broke something. I need to fix that.I noticed that ads are now popping up on the top banner - as a financial supporter I thought ads were supposed to be off? Has this policy changed?
I know Gerard, but as I wrote, until now I had two lines: first line was my name and in the second line I had my diy-gear listed. It's okay if there is a change now, I just wanted to know.Signature length goes up a bit with donated amount by the way.
I cannot see where that ad is getting injected - it is alarming as at the moment all ads are turned off at my end. This weird popping up from the bottom / top thing is rogue.Nope, I think I broke something. I need to fix that.
Yeah - wrong emoji.I don't know if this has been reported yet. In the private conversation between members; when you get a response from another member there is a prompt available for a thank you in the bottom right of the screen. When clicked it goes to the crying laughing imoji. It could be construed as less than polite.
Ye
Yes- I get a praying hands with thank you now. Right on!Emoji fixed now I think. . ..
I had many lines. 1 now. Not even an issue i have raised yet… more important things for the crew to do.Yes, I know, but until now I had two lines 🤔
dave
Don't know if mentioned already, but can the attached pictures thumbnails made to be more in focus?
Sure, but it is a feedback thread, so I thought every issue counts as an issue... but okay, I keep still.I had many lines. 1 now. Not even an issue i have raised yet… more important things for the crew to do.
dave
That changes much more than just the font. Yes it is a valuable technique which I use on another forum. Here I did not find so much help since enlarged decorations compete with the enlarged text.I just press control key and turn the center wheel of my mouse
The default Classic font is "same as before" within a few percent. What is odd, what you may understand better than us (being both a designer and an illusionist) is why is Dreamth "sure" the font has got smaller when it measures larger for me?Weird, noted. I'll be working on getting the classic theme as close to the original as possible over the next few weeks as a personal passion project.
The larger question may be so MUCH empty waste space. I know I am being an alewife (fighting upstream in the face of progress) but my scroll-finger is wearing out while my brain is bored for lack of content.
What is this "There are more posts to display. View them?" insert I see occasionally? And it is not always on-screen unless I am scrolling up/down to find where I have lost my mind/the thread. Related, new posts appear on apge 16 of a 20 page thread, like Time is looped. Time is looped. Time is looped. Time is looped. Time is looped.
What is
"Reactions received
Unfortunately, none of your content has received any reactions yet. You'll need to keep posting!"
Section in my Profile settings.
"Reactions received
The forum app has a reactions module which is turned off - but some of the effects of it are still visible. We do intend to later experiment (very cautiously) with some limited reactions. BTW I think you can "react" to a private message with a "thanks" even now.What is
"Reactions received
- Site
- Forum Problems & Feedback
- Welcome to the new diyAudio platform - feedback wanted!
