One definitely, but an array sharing the power? I'm sure they still have limits but those limits would be much greater than a single driver.There's no way they're using a 400hz crossover. The tweeters would blow up.
If you can’t/shouldn’t cross them low, what’s the advantage of the array. My hope was that this could be used from 400hz (or close to) and up. Removing cone speakers from the equation for the bulk of the audible frequency band. But this seems like just a large tweeter? I understand the added efficiency and directivity control, but was hoping for more.
Say you were running 8 tweeters, for a given output level each will be down 18dB. Would this be unusual at 400Hz for any typical dome with a moderately low first order filter used... and it isn't even that bad since no one is implying that output is flat at 400Hz.I'm sure they still have limits but those limits would be much greater than a single driver.
Directivity would not necessarily be as narrow, or controllable in different dimensions, or able to reach the top end requiring a tweeter anyway.
What is the final impedance of the tweeter array? It looks like very low and the amplifier will have trouble driving the combination of the 7 drivers. Can somebody please explain?
WA
WA
It's not a combination of 7 drivers as such. In the case of something like DI, it's 6 drivers wired in series-parallel being used as an upper-midrange array (where the drivers are also cascaded, so the horizontal-plane units are rolled off first, then those on the vertical), and crossing over to a single central tweeter. In the case of Moab etc., it's 2 clusters of 7 tweeters wired in series parallel in a large MTM with a single central dome; it's straightforward enough to control impedance (and level matching) with series or damping resistors as necessary.
I think they'll be rather thin on the ground after last week...
The situation has been discussed in a recent thread - linking to the final post:
https://www.diyaudio.com/community/...t-from-audio-karma.411513/page-2#post-7657823
The Tekton reply I saw seemed odd. The speakers I make for myself aren't neutral, or playing a linear response. They are unabashedly coloured to suit my own taste.
It seems odd to say on one hand a speaker is extremely flat in response, and on another hand to sat it is made for audiophiles, and not linear, as that would be more suitable as a mixing monitor.
Two of my cents while living in a country without pennies.
dispersion and room response to that dispersion are a bigger deal than most realize
flat on axis often doesn't tell the story all that well
- Help Understanding Tekton Tweeter Array Schematic?
