Hello ,
I have 20 year old speakers ,. That apparently use Vifa drive units.....mid + bass woofer
The outer diameter of both mid + woofer chassis/frame is 155mm.
DCR on mid. is 6.6 OHms ,. Both sides measure the same . DCR on parallel woofers is 3.3 ohms. Both sides measure the same ( so seems that a single bass woofer also has DCR 6 6 ohms )
The closest I can see is the Vifa M17WG-09-08 , at 170mm
I have spent hours looking at Vifa data sheets and do not see any 155mm external diameter drive units .... 149mm then 170mm are the closest
The speakers are SD Acoustics , a small UK company ( no longer exists ) so I can not imagine these bieng custom made for such small quantities
Any help much appreciated
PS:- is the zobel on the midrange necessary ,. If I'm using a SS amp ?
The mid. uses no crossover ..... SD called it ' semi active design ' (!) .....Bass is 2nd order
That's a good question ...
Well the guy who sold them stated they had Vifa drivers .... And a magazine review verdict, said they used high quality drivers ( I never saw the actual full review )
But yes , realistically I just don't know
I thought the bass woofer looked a lot like the woofer below ;
Old Vifa's with a steel basket either are 146mm for the round C13 or 166mm for the C17. There also was a C11, a truncated C13 and a C20, but that isn't relevant here. The units don't look Vifa to me, e.g. the terminals of Vifa have connector spades for both sizes of cable connectors. These don't
Re: zobel, who's to say without measuring the response with/without? Given that most manufacturers cheap out on the components, it'd seem more likely it's there for a reason.
I don't think the bass driver is Vifa as I also don't recognize that "Dynaudio shaped" flat cone style from any of their old catalogs.
Why do you think these are Vifa drivers?
Thanks for the info Mark ,. That explains why I couldn't find a 155mm vifa ( they don't exist !) .... Much appreciated ....
Re: zobel, who's to say without measuring the response with/without? Given that most manufacturers cheap out on the components, it'd seem more likely it's there for a reason..
Thanks , I will measure with + without zobel .... I bought these as a project , the tweeters are not original ( and are crossing at 10khz 1st order )....the mid has strong output from 200 - 5khz
The woofers output to 800hz before dropping off
The sound is seriously bass heavy....mushy slow horrible bass ( in fact just using the midrange alone , the sound is very clear , with good vocals....)
Overall a sonic disaster ( so far ) ...but the cast resin enclosures are superb... V heavy and resonant free
They look like they have two magnets and two top plates giving it two magnetic gaps like the new Dayton Epique's have only with a stamped steel basket and ferrite magnets? 20 year old drivers could be SEAS or ADS or Foster drivers but more likely a Chinese OEM. They could even be made by Peerless to some companies specs. It's hard to say and with the photos you posted being so compressed and blurred I can't make out any detail so I'm just guessing.
Here is another thread regarding these speakers and it's thought that the drivers are AUDAX.
Driver/Speaker Identification (SD Acoustics)
Thanks .... They do look like Vifa / Peerless ,. The midranges are flat to about 6khz ,. Very impressive
The photos are high Res ,. Must be compression by this website
- Anyone recognise these old VIFA drivers ?
