Complementary Power MOSFETs
The truely complementary pair of MOSFETs 2SK1530 / 2SJ201 is now unobtanium.
Even our own stock has been depleted.
The search for alternatives has not stopped, however.
We have previously had good experience with the Fairchild FQA9P25.
https://www.diyaudio.com/forums/solid-state/343164-udness-dont-semisouths.html
So we have been looking for some time for a compatible N device.
https://www.diyaudio.com/forums/pass-labs/369546-f5-2sk1530-2sj201-post6577901.html
Finally I got one sample of each and curve traced them.
Here is the result.
The NMOS has a Vgs pf 5.5V at 1.3A, and a Yfs of 3S.
The PMOS has a Vgs of 5.2V at 1.3A, and a Yfs of 2.7S.
In the graph below, the Vgs is manually aligned to 0V at 1.3A for ease of comparison.
As this is only one single sample, it is difficult to tell whether the difference is statistical or systematic.
But there is a reasonable chance that even better NP match can be found in a larger batch.
Patrick
Reactions: pbilous
How do they compare with IRFP240/9240 ?
Ignore the well-known problem of the IRF PMOS for now.
The values listed below are Device Type / Vgs at 1.3A / Yfs at 1.3A / Ciss / Coss / Crss.
Units are Volt / Siemens / pF / pF / pF.
IRFP240 / 4.50 / 3.20 / 1300 / 400 / 130
FQA10N80C-F109 / 5.50 / 3.00 / 2150 / 180 / 15
IRFP9240 / 4.00 / 3.00 / 1200 / 370 / 81
FQA12P20 / 5.52 / 2.70 / 920 / 190 / 30
These values vary typically ~10% for Vgs and 30%for Yfs.
PassDiy
N-P Vgs difference can be anything betwwen 0.1V to 0.5V for the IRFP's.
And not only between devices, but also between batches.
i.e. there is no perfect N-P match on average between the IRFP's
For a circuit like the F5, the ~10% lower transconductance is more than compensated by the ~20% higher bias voltage.
The FQA NMOS does have a much higher Ciss, so a high-Idss frontend is desirable.
For a circuit like the F4 or M2, only the Crss is important.
The FQAs are a clear winner there.
The difference in transconductance to the IRFPs is equivalent to 0.01R.
If it should ever bother you, you can simply reduce the source resistor by the same amount.
Patrick
This is how well they match if a 0.03R resistor is added to the source of the NMOS.
Of course this is well within the variations of Yfs in a large batch.
That means the chances are that you can find N-P match also in Yfs without this R_source trick.
Patrick
Fair enough.
The next question is, does the higher threshold voltage of the FQA devices require some adjustment to work correctly in the M2 output stage?
BTW: I have already made an FQH44N10 substitution for the output devices in my F6. That worked brilliantly.
I pulled the R-source trick in the production version of the ACA mini -
while I'm looking for a generally 2nd harmonic character to the
IRF520 and IRF9520, I put a jumper in to RC bypass the P channel
source resistor and take the 2nd down by 70% or so. People can
pop the jumper in and out while they listen...
And those are the Harris parts.....
:snail:
Next on the queue -- FQA36P15 / FQA28N15, as used in Accuphase power amps.
That is after they were forced to switch ti Fairchild.
Degen is 0.04R on NMOS when applicable.
Yfs at 1.3A = 3.37S & 3.79S (raw).
Patrick
Last but not least, 2SJ618 / 2SK3497 as used in Accuphase power amps before switching to Fairchild.
Simply because the Toshibas became obsolete.
Degen is 0.05R on NMOS when applicable.
Yfs at 1.3A = 3.75S & 4.43S (raw).
Highest of all. Also much lower Vgs at ~2.4V.
Patrick
