Germanium investigations
NTE105, Транзистор: PNP; биполярный; германиевый; 40В; 15А; 150Вт; TO36 | купить в розницу и оптом
just measured 0.141% distortion at -10dB level
not bad
I can see second harmonic ~-60dB, and third ~ -80 to -90dB, depending on the current I set with trimmers
....and hf rollof is still there
but it sounds awesome
done!
this is when cranked up at 20volts with LM317 regulator
distortion dropped to 0.076%, intermodulation at 0.101%
I will build another version, with bigger heatsinks
Congratulations 🙂 Any news about your Ge amp ?
Almost Germany amplifier. Transistors GT703 and GT705. Output power is about 50W. It is advisable to apply an operating amplifier with a supply voltage + -18 ... 24V.
Reactions: bluevas
Hi Adason. Could You please post the final shematic, preferably with some DC points measured and 2 resistances of bias pot measured? I cant find what part of Ge power transistor You used? Thanks 🙂
Hi Zoran, sorry for late reply. I have not been following this thread anymore.
To be honest, i was not so happy with the result and i got distracted with other projects, especially those based on power jfet lu1014d. Since there was gb on adapters, and i got some jfets from Mr. NP, and bought many from aliexpress.
I built f1j and f3 with lu1014d. Great stuff.
Since i got plenty, i guilt headphone amp too.
I know its not germanium, so i am not going to post it. Just saying that the sound was way ahead, so i am finishing lu1014d into box, plus i will work on perfect power supply for it. I scavenged my germanium headphone amp for parts.
If you have lu1014d, build headphone amp i posted in 'whats on your bench tonight' thread. You will like it.
Its one of the best headphone amps i have (and i have about dozen icluding few shiit, acp+, whammy...).
