3 Band Equalizer Not Working
I recently built this circuit
but It Is not working Not getting any sound after building this circuit. Idont know where i have made a mistake.
Thanks In advance
First:
Connect the black meter lead to ground.
Connect the red meter lead to the negative (-) input op amp pin #6.
What does the meter read?
Second:
Connect the red meter lead to the output op amp pin #7.
The similarity to the circuit in post 15 is ........ uncanny 😀😉
You need to (re) go over you work meticulously , looking for inadvertant shorts (not just to ground but to other circuit areas) or breaks
and/or 'scope the signal as it travels from node to node..
Gotta be a wrong connection, flipped polarity, etc.
Just to reassure you, many circuits won't work right the first time, since
there are too many places to make a mistake. Not at all unusual.
