I fail to see any other theme in post #1, except 20% vs 5% tolerance (and confirmation bias in one sentence).
The "and" implies two different things to me, the bias connected to supposed "expensive is better" statements from goodness knows where.
No, you are wrong! I would happily accept results of any science-based test.Just something for you to chew on…….anything I might link or say is never going to be good enough so I thought maybe you could take a look at those things wherever it is you trust for information to come from.
Yes - every ABX test done up till now.You know maybe some tests that prove those things are inaudible? 😛
Yes, I want the proof.Bob, he want's proof.
Don't you want or need a proof? Lucky you...
This from airvoid, "As neither you nor the op seem to grasp, science does not provide proof but only conclusions drawn from facts and observations, as a propagandist for science I find this sorely lacking in the above." is far more meaningful to me than any demand or need for proof.
“ Yes - every ABX test done up till now.”
Please link some that reflect testing of those parameters I mentioned (DA, EMR, ES, FRes)
I have to correct myself, but not in the way you want. There is scientific evidence, not scientific proof.This from airvoid, "As neither you nor the op seem to grasp, science does not provide proof but only conclusions drawn from facts and observations, as a propagandist for science I find this sorely lacking in the above." is far more meaningful to me than any demand or need for proof.
So, the science does not provide only "conclusions drawn from facts an obsevations", but in fact provide evidence.
Scientific evidence - Wikipedia
Nobody here provided scientific evidence supporting the idea "expensive caps are better".
??? 😕 ???“ Yes - every ABX test done up till now.”
Every ABX test involves at least two different capacitors.
In which way they are different? Different DA, EMR, ES, ...
Specifically testing that may compare measurements of these parameters to audibility, for example thresholds of what may or may not be audible within said measurements.
Why are you looking for quantifying audibility thresholds, when all capacitors, including the dirty cheap ones, are indistinguishable from expensive boutique caps in all ABX tests?
If that was actually true we could easily toss ABX tests (which aren't the only useful test) out of the window. 😉 Could we please stop with the extreme pontifications, they're not helpful for those of us who want an interesting discussion, which has developed, amazingly 🙂Why are you looking for quantifying audibility thresholds, when all capacitors, including the dirty cheap ones, are indistinguishable from expensive boutique caps in all ABX tests?
Yes, it is true. And no, you can not toss ABX tests - you can not toss the scientific evidence that cheap and expensive caps sound the same, only because you don't like that scientific evidence. I don't like coffee, by the way (I prefer tea).
ABX test is science, heavily involved in debunking audio myths.A baseline…….just trying to involve science!
That isn't what you said though is it?cheap and expensive caps sound the same
I don’t accept abx testing as the end all for this particular debate.
My testing has been consistently repeatable and the only thing that drives me is curiosity, these bias that keep popping up don’t really matter to me as I put very little importance on which brand capacitors sound ‘best’ in my system……..it so happens one of my most expensive caps I’ve ever bought sits in the parts box because I couldn’t make it work on any of the setups I tried it in.
My testing is a bit unorthodox to most, I test at extremely high spl levels……..in fact that’s how i objectify my testing by peak spl @ lp, it’s fairly obvious at high spl when distortion kicks in. Disclaimer- if done improperly this method can lead to hearing damage…….proceed at your own risk. My conclusions come from almost 2 years of testing…..not just some random day of cap swapping.
There’s way too many people that agree with my stance, I just want to know why I hear the things I do…….not be told its a overactive imagination…….I eliminated that possibility through extensive testing.
Is it hearing damage, Bob? 😀
Just a wild guess 😉.
ABX testing is 50's methodology. The dual pair (4IAX) discrimination method (f.i) is demonstrably better:
(PDF) A Thurstonian model for the dual pair (4IAX) discrimination method
Science strongly objects on this one!I don’t accept abx testing as the end all for this particular debate.
Anyway, you don't accept science evidence, so it doesn't matter.
Oh, really? Try the ABX test sometimes.My testing has been consistently repeatable ...
And you just throw the science trough the window... again.My testing is a bit unorthodox to most, I test at extremely high spl levels...
Overactive imagination is more stubborn and stronger than any nonscientific "extensive testing".I just want to know why I hear the things I do…….not be told its a overactive imagination…….I eliminated that possibility through extensive testing.
Excellent! So you can post, or give a link, to a peer-reviewed paper using this methodology, demonstrating difference in capacitors?ABX testing is 50's methodology. The dual pair (4IAX) discrimination method (f.i) is demonstrably better:
I can hardly wait...
- Should You Change Crossover Capacitors – The Great Debate
