active crossover PCB
The board looks well designed, and he has multiple versions, for two, three channels. I didn't it see an schematic but it seems it's just the crossover. Normally a speaker has also baffle compensation and other filters. looks great for prototype and you can design an addon board if you need extra functionality. As reliably, looks good
He made the PCB like this . with no output buffer but as you mentioned we could add buffer if we want to .
Just for test I build today like this schema with no output buffer and it working good with no issue .
Unfortunately the vast majority of the active filters boards available work extremely poorly. (no offense)
With that I don't mean the quality, but the type of filters that are being used. (or the lack there of)
Even Elliots design doesn't make any sense at all if you're familiar/experienced with loudspeaker filter design.
For a good filter design one needs at least a shelving filter,
and two channels with at least 2nd or 3rd order LP/HP, param EQ/notch (per channel) as well as adjustable gain for one channel.
Currently I am busy developing such board.
It even has to option to route certain filter blocks differently.
By default it can be used for a 2-way system or 1-way system with more options, or can be used as a subwoofer filter.
Opamps can be picked by the user, adapter boards will also be available (for using SMD variations)
Multiple cards can be used as well.
At this moment I'm in the stage of writing a manual for this board
(which is taking far more time than doing the PCB design itself)
The idea came from another project/job I had to do, and decided to translate it to a little more DIY friendly project.
I don't know how much of a rush you have, because it will take a couple of weeks to finalize everything?
Here some pics as an impression, not final product yet.
Board size 80x40mm, will work on symmetrical power supply (regulators are on the PCB), and in the future there will also be an option available to use it on a single supply.
Spreadsheet will be available as well to easily calculate all values.
To do active XO with op-amp I have learned .and totally satisfied . it is a big improvement over passive XO .
About DSP XO , I have to dedicate some time to learn how to work with it .
There's been quite a few DIY active crossover board projects here on DIYaudio. (A number of group buys as well.)
The problem with these (as mentioned earlier) is the topology doesn't always support your real-world project.
You might design a board with a shelving filter in Leg A and a notch filter in Leg B, (or whatever setup you need.) But then another speaker project comes along which needs a different scheme and your board won't support it. So, you have to design another board. 🙂
Or, you might design a "universal" board with all sorts of function in every leg so you have all the bases covered, but then you find yourself not needing 80% of the capability. 🙂
DSP, inherently, eliminates all these issues.......and adds myriad other capabilities as icing on the cake.
Dave.
Unfortunately the vast majority of the active filters boards available work extremely poorly...... Even Elliots design doesn't make any sense at all if you're familiar/experienced with loudspeaker filter design.
That's a pretty BOLD statement, given Mr. Elliott's pedigree as one of the most astute DIY Audio designers we have. Do you have something to back this up?
I know Elliot, I have read his website for over a decade.
Wonderful stuff, always fun and nice to read, absolute love his website!
I often even refer to his website!
But that doesn't mean it is the holy grail?
Hell, he even says that himself!
There is nothing bold about this statement.
Just look at an average filter that is needed and see if you can fit it in that filter board.
I personally don't really understand the whole offensive mood?
Don't really appreciate it to be honest.
I have been professionally working on and designing these active boards for over a decade by now. Last few years we changed everything to DSP yes, but before it was all active analog designs (for close to 30 years by now if I am not mistaken)
So I think I know a thing or two when I see such boards, just saying.
At least spell Rod's name right---it's E--L--L--I--O--T--T.
You still did not explain what about the design of his active crossover project:
Project 125
that "doesn't make any sense at all if you're familiar/experienced with loudspeaker filter design."
I think it's a quite elegant design, and fits the bill exactly.
Suggest you publish a few of your own designs, before trying to get points by attacking one of the few serious, practical and no nonsense resources on the Web.
Personally I find it despicable, but hey, maybe it´s "normal" in your close group of acquaintances.
Adding the usual BS disclaimers
Have a nice day!
Bless!
